Results 31 to 33 of 33
Thread: Free Handsfree Solution
  1. #31
    Sep 2009
    I can get A2DP from my iPhone through my Fiscon.
    I only found out because for some reason (very occasionally) after I hang up a call I start getting iPhone music through the Bolero. As long as the phone is in my pocket and not connected to the MDI in the glove box it's easy enough to stop and I must admit that it only happened two or three times and hasn't for ages.
    BTW there are two other things about the Fiscon that are worth mentioning.
    If you have a large number of phone numbers (I probably have close to 500 contacts many with multiple numbers and email addresses, etc) the Fiscon Bluetooth takes way longer to start up than the Bolero music from an SD card. Makes the SD card look fast actually.
    When a call comes in it shows on the Bolero screen and an "unknown number" until you answer it. Once you press the answer icon the number shows or if the person is in your address book their name shows. If you want to screen calls while you are driving the Fiscon is not good.
    My Škoda photos here
    Flickr : Blog
  2. #32
    I had music come via my handsfree Blueant unit yesterday, it wasn't supposed to be doing it, and yet it did.
  3. #33
    Apr 2009
    Thanks Dodgey, I will investigate if anyone in SA supplied and installs the Skoda kit.
    Thanks kiwi for pointing out this issue about the Fiscon not being able to show call identity until you press 'answer'! Well, i do like to screen calls, especially while driving, but if I can't find anyone installing the Skoda kit in Adelaide, then I will have to live with the Fiscon.
