Indicators on all night will not flatten the battery.
You won't believe how many finishing touches there are that will "surprise & delight" you.
I have been going through things, but could not find anything on it. I have had something plugged in for over an hour with the ignition off and the alarm/central locking set, and the LED is still showing. There is a note in the manual that you have to have the ignition on to use them, however not here.
Under which section is it?
Thanks.
did u retro fit a columbus (rns510)?
i've heard of the these units draining the battery when retro-fitted to the pre-fl models.
something due to the canbus.
MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
Sorry, had a look but can't find the reference. My 98 Golf had the same feature so I assume it was a universal standard for VW group cars. Mayne I'm wrong.
If you switch of ignition & remove keys then turn on radio/cd, how long does that go for? It should be a similar amount of time.
I use the 30 minute feature to charge my phone/GPS.
