Results 11 to 20 of 27
Thread: Flat battery/ voltage drain
    Quote Originally Posted by wai View Post
    Just thought of another one.
    Make sure that the turn indicators are off otherwise the parking lights will be on on the side the indicators would be lighting up normally.
    That sounds plausible
    Sep 2009
    Indicators on all night will not flatten the battery.
    My Škoda photos here
    Flickr : Blog
    Erskineville, NSW
    I have a 2011 Caddy Maxi Life and discovered that the 12 V sockets remain live even when the ignition is turned off.
    You might want to check that you have no accessories plugged in that are running even with the ignition turned off.
    for 30 mins. It's in the manual.
    Erskineville, NSW
    Quote Originally Posted by pologti18t View Post
    Does the Octavia have a "body" computer that shuts off all interior lights, stereo etc after a certain time with the ignition key removed?
    yes. varying time periods depending on settings
    Jun 2011
    Sydney NSW
    Well i'll be...
    My first weekend with the Caddy so it will be some heavy reading
    Erskineville, NSW
    You won't believe how many finishing touches there are that will "surprise & delight" you.
    Jun 2011
    Sydney NSW
    I have been going through things, but could not find anything on it. I have had something plugged in for over an hour with the ignition off and the alarm/central locking set, and the LED is still showing. There is a note in the manual that you have to have the ignition on to use them, however not here.
    Under which section is it?
    Thanks.
    Jul 2010
    did u retro fit a columbus (rns510)?
    i've heard of the these units draining the battery when retro-fitted to the pre-fl models.
    something due to the canbus.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Sep 2009
    The same problem was happening with the eBay copies as well.
    Flickr : Blog
    Erskineville, NSW
    Thanks.
    Sorry, had a look but can't find the reference. My 98 Golf had the same feature so I assume it was a universal standard for VW group cars. Mayne I'm wrong.
    If you switch of ignition & remove keys then turn on radio/cd, how long does that go for? It should be a similar amount of time.
    I use the 30 minute feature to charge my phone/GPS.
