Hello,
I noticed over the last few days that sometimes after I unlock my Nov 09 build Octavia there is an audible warning (dinging). This dinging seemed to be intermittent, and was not accompanied by any warning signal on dash. It happened both with and without the auto lights on. I could not find any mention of it in the manual and as it didn't seem to impact the car once started I dismissed it...
I went to start it yesterday and it was dead... flat battery. I called Skoda Assist and they called out the RACQ (like NRMA/RACV). It needed a jump start but the mechanic said I should take it to the dealer. In his opinion it should not happen on a new car.
The dealer had a quick look, tested the battery (ok), checked that it was charging (ok), and checked for error codes (none). Basically they could offer no explanation as to why it went flat. It's not even like it gets cold here in QLD and it gets used everyday (albeit for short trips).
He didn't hear the dinging and could not offer any suggestions as to what it might be... It could of course be unrelated. It's just weird that the car started making this noise just before it went flat.
Yesterday after the jump start I didn't hear the dinging again, but it was there again this morning after the car sat overnight. If this dinging is related then going on what happened last time the battery will be flat again in a few mornings time.
Any suggestions on things I can check myself that could be the possible cause of the voltage drain?
