Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Flat battery & now the steering is heavy
    Melbourne, Vic
    Quote Originally Posted by woofy View Post
    Ours hit 5yrs old in Nov, I just put a new one in for future insurance. Its only done 50k in that time so not high milage, but batteries don't seem to care about kms.
    The RACV here did it, and they plug a device into the lighter socket to keep all the electrics alive so you don't get any surprises. Car behaved like normal afterwards.
    I swapped a battery over on my A3, had one of the lights on (as per the manual for about 1 km), then all good.
    Did a full disconnect, pull battery out. Put new battery in, stuff around 20mins trying to line battery cover/well up again, connected new battery, then set date/time in the car and drove off. (it went flat while parked at train station)
    No issues with steering etc.
    Need to check that VCDS steering weighting, you can do it in A3 and A4, so would have expected RS as well.
    I have wiring diagram for Octavia, if you need it for the lights.
    2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
    2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
    2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
    2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
    Erskineville, NSW
    Quote Originally Posted by spud75 View Post
    I have an Elegance.
    I've changed the weighting on a Polo - can't find similar on the Octavia.
    The wiring diagram would be appreciated as I want to check the continuity of the circuit between the headlight plug & the parking light.
    I'll PM my email address. thx
    I think my problem was trying to start it with the flat battery. Possibly something to do with the kufatec e-MFA information add-on thingy as it's dissapeared off the multi-function Display menu (maybe coincidence).
    Bowral, NSW
    The steering sensor needs to know how far it is from one end of the steering range to the other, same with the windows.
    I know that after I disconnect/reconnect the battery in mine the windows won't auto-up/down until I've done it manually on all four, same with steering; its at full 'power sterring power' and almost whacks into the stoppers at each end, then after that the light goes off and the power steering tapers off before it stops assisting all together when you're doing a 3-point turn.
    Lucky for me I need to go to both locks to get out of the driveway so I don't need an excuse to turn the wheel lock-to-lock to get it working again!
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Apr 2012
    Cherrybrook NSW
    I need to bear this little idiosyncrasy in mind if ever I have cause to disconnect the battery or if it goes flat - I would've thought these settings would be retained in non-volatile memory somewhere. The windows not a biggie, but the steering could be a real trap.
    MY 22 Superb Sportline Wagon. Moon White.
    1985 BMW K100RS in JPS racing livery
    2019 BMW R1250GS Exclusive
    Dec 2012
    Sutherland Shire, Sydney
    This PDF is also a handy overview & quick reference
    https://dl.dropboxusercontent.com/u/...tavia%20II.pdf
    Apr 2009
    Northern Tasmania
    That's a handy pdf. Thanks.
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
