Results 1 to 7 of 7
Thread: Firewall Grommet
    Bowral, NSW
    Firewall Grommet
    Hey, all.
    I remember seeing somewhere that someone had run some wiring for an amp through the firewall into the cab... I can't find the post (yes, tried searching) and was wondering if anybody could point me in the right direction.
    Either that, or provide a full write-up on how to get to it.
    I've tried looking around under the dash, but can't find anything.
    I want to run the lines for removable UHF and 3G aerials, for those long drives and for work (Lots of remote places), but I can't find anything about it.
    -Myst.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Sep 2009
    Did you try looking at the firewall from the engine side? You may be able to see where wires come through from there.
    My Škoda photos here
    Flickr : Blog
    Apr 2009
    Northern Tasmania
    It's sewn up tighter than a nuns whatsit under there. What about drilling a new hole?
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
    Dec 2008
    Sydney/Canberra
    There should be a harness that passes through the firewall on top of the left front chassis rail. The grommet should be big enough to share with the wiring you're passing through there.
    PM me if you get stuck. I'm local to you.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Gosford Central Coast NSW
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Bowral, NSW
    Cheers, gldgti!!
    Would it be possible for you to post a couple of pics, from the engine compartment side?
    I have to run the wire from the front into the cab, cause it doesn't detach at the other end. >.<
    Thanks, Umai.
    I'll let you know when I'm actually hooking the gear up to the vehicle.
    Have you attempted to examine the firewall from the engine side? You may be able to see where wires enter from that location. geometry dash
