The cheaper, simpler and legal option is to put brighter halogen globes in. After trying out many different brands and models of globes I recommend Osram 65W (H7) and Philips X-treme 55W (H1 & H4).
Before you go down the HID route you might want to do some research on the following issues (there are heaps of threads around about the pros and cons of aftermarket HIDs, and lots of heated discussion too) :
Excess glare for other drivers from putting HIDs into optics designed for Halogen globes.
Error codes due to HID globes using less current than the std Halogen globes.
HIDs on lo beam are not roadworthy unless:
- installed in headlights that are designed and certified for HID globes, and
- self-levelling mechanism, and
- headlight washers are also fitted
(this is all very expensive to do retro-fitting or aftermarket).
Car is uninsured if not roadworthy.
Adding HIDs is a modification to your car that you should tell your insurer about.
Aftermarket HIDs on Hi beam only is generally not so closely regulated (as you are supposed to dip to LO beam when there are any other cars around). In the ACT the registration authority doesn't care about Hi beam, only that you leave Lo beam as OEM. I have fitted HIDs to Hi beam of my Transporter van. The biggest disadvantage is the time they take to get to full brightness after you switch them on.
What "colour" HIDs are best ? (OEM are usually around 4,300K)
Cheap'n'nasty ballasts can fry your cars expensive electronics.
Regardless of the above, fitting aftermarket HIDs is quite a popular mod.
It is your car, so you make the choices (and live with the consequences of your choices).
