Results 1 to 10 of 13
Thread: Engine Noise
    Sep 2014
    Newcastle, NSW
    Engine Noise
    All silly questions and answers aside.
    I have a Used Facelift 2010 Octavia Rs 147TSI (49,000km). I have noticed since owning it there is a noise coming from the front section of the engine that getting louder. Even when I'm cruising you can hear a faint noise.
    Would this be linked with the timing belt or even the fans??
    Thanks in advanced 😀
    Oct 2010
    If its a 2010, it will have the tsi motor (not tfsi), so cam chain. They have a known issue with the tensioner. Get it checked out by an independent service specialist.
    2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
    Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
    Ethan is it a ticking noise? And the ticking gets faster if you rev the engine a bit? If so its just the fuel injectors which are quite loud on these engines.
    We can meet up quickly over the weekend if you want me to have a listen.
    Jul 2010
    the ticking of the injectors on the ea888 tsi motors are known to b noisy.
    its "normal" operating conditions.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Sep 2014
    Newcastle, NSW
    Hey,
    Thanks guys for the info. I'll be sure to get it looked at. Lucas_R, only if you are available, can you please pop past on Saturday, I'm still at Newcastle Skoda
    Dec 2012
    Sutherland Shire, Sydney
    The engine has a timing chain, not a belt
    You only heard the injectors from outside or when looking under the bonnet
    You can't hear the injectors from inside the cabin
    Oct 2010
    Injectors make a ticking noise, sounds different to can chain noise. YouTube vw 2l tsi cam chain noise and injector noise and see which one is closest to your noise
    Jul 2010
    i'm referring specifically to the injectors - the ticking noise that can only be heard from the outside/under-bonnet.
    can't hear it from inside.
    Sep 2014
    Newcastle, NSW
    Cheers Guys!
    Had a look at some YouTube videos and there was one with a White GTI that started up and sounded similar to mine. (My car being way superior to any golf &#128540
    So I'm starting to relax a bit knowing that's it's not only car that make this noise. Is there a way to make it quieter? Or it is what it is??
    Plus there is a rasp-ish noise with the turbo under moderate acceleration. Have I not waited long enough for the car to warm up or is this a different area, if so can it be resolved?
    Engine Noise
    ^ that rasp is more than likely the wastegate on the turbo rattling. You can get a metal clip which reduces the sound by about 90%. I have one on our GTI.
