Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: EA888 Water pump failure
  1. #21
    Bowral, NSW
    I think it would be better / cheaper if you set up either water/meth injection or started doing chemical cleaning every 7500km
    Set up wha? I have no idea about these things.
    Was looking into the Provent, but haven't had much time to do any decent googling.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  2. #22
    Erskineville, NSW
    Quote Originally Posted by Mysticality View Post
    Look in the deisel section. Can't remember the thread but it's like permanently cleaning the inlet.
    I used to run electronic water / meth injection on my 2nd & 3rd cars - XT Falcon & a Capri. Worked well on the Falcon. Nothing could help the Capri.
  3. #23
    Jan 2012
    those things (IMO) are dangerous. water/meth setups were to cool the charged air to prevent pinging. FMICs and engine developments removed the need for these. when the water/meth runs out and you dont have access to either, what do you do then?
    if you want to keep the inlet manifold clean, use an oil catch can and run a cleaner through it regularly. also good quality oils prevent clogging and take the car on long trips so everything stays hot for a long time, not only does that help the intake, it also assists with removing carbon buildups
  4. #24
    Erskineville, NSW
    Quote Originally Posted by zei20t View Post
    If you add the water/meth injector & change nothing else then when it runs out you lose nothing.
    I don't think I ever ran out previously. Biggest issue was clogged jets.
    It isn't hard to carry a 2 litre milk bottle of water in the boot.
    I already use quality oils changed every 7500km & 90% of my trips are 45km+ at motorway speed.
  5. #25
    Jan 2012
    then chances are most of us here will probably have no problems due to long trips and the oil can get up to operating temperature and stay there for a while.
  6. #26
    Adelaide hills, SA
    I thought that you change the oil every 15,000km?
  7. #27
    Erskineville, NSW
    Not the last 30,00km. I was given 17L of Castrol 502.00 in exchange for a carton of beer & had 5L of Shell 507.00 sitting on the shelf so I thought I better use it before it went "off". So I've done 2 interim changes & have another coming up next month.
    Daughter will start learning by then, so it will be lots of short trips, therefore "severe service" so will probably keep it up.
