Yep. that's what they are using. It's not like the old SUbaru UCS stuff. This foams.
We will be trying to work out what to remove so I can foam it up every 15,000km.
Subaru top-end engine cleaner will fix that right up!
the new foam stuff works wonders!
take off as much as you can. if youre removing manifolds, best to just clean it while its off.
Got a call about an hour ago. ready to rock & roll.
... They can clean up all the EGR gunk, at Camden GTI?
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
I guess so - they were cleaning something on a diesel that required manifold off. I was in a bit of a hurry doing Mr Mum stuff & didn't look beyond my own car.
I think it would be better / cheaper if you set up either water/meth injection or started doing chemical cleaning every 7500km
Theres a inlet temp sensor at the front of the inlet manifold which is what i use when doing carbon cleans. 1x screw and its out.
http://www.vwgolf.net.au/showthread....l=1#post205717
Thanks Lucas. That looks like the solution.
Just did a quick search on eBay. There's a seller in there that has the water pump pulley/impeller for $80 delivered to AUS.
part number FWP2224. I bought the whole housing, impeller & a pipe which was ~$750ish. I'll get the straight edge onto my old housing & see if it's re-usable.
