Results 11 to 20 of 27
Thread: EA888 Water pump failure
    Jan 2012
    Subaru top-end engine cleaner will fix that right up!
    Erskineville, NSW
    Yep. that's what they are using. It's not like the old SUbaru UCS stuff. This foams.
    We will be trying to work out what to remove so I can foam it up every 15,000km.
    Jan 2012
    the new foam stuff works wonders!
    take off as much as you can. if youre removing manifolds, best to just clean it while its off.
    Erskineville, NSW
    Got a call about an hour ago. ready to rock & roll.
    Bowral, NSW
    ... They can clean up all the EGR gunk, at Camden GTI?
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Erskineville, NSW
    Quote Originally Posted by Mysticality View Post
    I guess so - they were cleaning something on a diesel that required manifold off. I was in a bit of a hurry doing Mr Mum stuff & didn't look beyond my own car.
    I think it would be better / cheaper if you set up either water/meth injection or started doing chemical cleaning every 7500km
    Theres a inlet temp sensor at the front of the inlet manifold which is what i use when doing carbon cleans. 1x screw and its out.
    http://www.vwgolf.net.au/showthread....l=1#post205717
    Dec 2009
    Sydney NSW
    Water pump failures in the EA888 seem to be a more common fault than the norm. I had one replaced inside 10k.
    yes wp failures are well known. I am on my 3rd water pump, 1st one at 15k kms and 2nd one at 45k kms,.....
    mk VI GTI, manual, reflex silver, basic
    Erskineville, NSW
    Thanks Lucas. That looks like the solution.
    Erskineville, NSW
    Just did a quick search on eBay. There's a seller in there that has the water pump pulley/impeller for $80 delivered to AUS.
    part number FWP2224. I bought the whole housing, impeller & a pipe which was ~$750ish. I'll get the straight edge onto my old housing & see if it's re-usable.
