Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Dunlop tire noise?
    Jun 2009
    Quote Originally Posted by mintygreen View Post
    The sidewall advised 'max of 50psi or kpa' I've been running them at 40, maybe dropping them to 35 might help?
    I have read that the reccomended PSI is 10% less than teh maximum on the sidewall.
    That means you should be running 45PSI.
    Erskineville, NSW
    rotated them front to back (directional tires). and sure enough, now the noise comes from the front.
    This is the one & only reason i don't like directionals.
    May I recommend Goodyear F1 Assymetrics? Tirerack has stupidly low prices on them.
    Erskineville, NSW
    Quote Originally Posted by team_v View Post
    ummm....no.
    That's a very rough & ready way of doing it. The other rule of thumb is tyre placard on the fuel flap plus 10%, which would make it around 33psi. The answer is probably somewhere between the two figures.
    Personally, my happy medium is 36F/34R but that is on 205/55x16. My Mk3.5 Golf had 205/45x16 & was much happier on 40F/36R. So it's all down to a bit of experimentation & testing & if you change tyre brands, then it starts all over again.
    What matters is the load in the car, style of driving, suspension setup & the tyre. There is also the compromise between grip (lower pressures give more lateral grip) & sidewall stiffness (reaction speed, turn-in, etc).
    Feb 2010
    Perth
    Think i'll look at non-directional tires next, to allow more flexibilty to rotate for uneven wear.
    In the meanwhile i'll play with tire pressures.
    Ta for the info.
    Mar 2009
    Mount Pleasant, WA
    Some tire/tyre noise info ( a bit old)
    Still interesting http://www.silentroads.nl/downloads/...asurements.pdf, especially figure 4 on page 11.
    3dB change is a doubling in intensity=loudness, so the differences between tyres is significant. db(A) is just a weighted sound measurement that takes into account that our ears are more sensitive to some sound frequencies than others.
