Results 11 to 20 of 29
Thread: DSG affected by heatwave?
    Nov 2009
    I've driven literally dozens of DSGs, including several on the MQB platform, and many in high heat and on track. The only time I've experienced this behaviour is in the Skoda, in 40 degree ambient. The car was near-brand-new (oil did not require changing and the 'box did not require servicing), the gearbox was otherwise operating fine - shifts were smooth, clutch operation perfectly normal, etc etc. It had me moderately concerned at the time because the behaviour was new to me. As I said, manual shifting was perfectly normal - so clearly the gearbox was not preventing gearchanges, it was simply using a different shift programme for one reason or another. The shift patterns returned to normal on the next drive (next day) with ambients back in the 20s.
    Minimising shifts to keep temps low seems like a legitimate explanation to me - although I've not experienced this in GTIs or Rs driven on track for extended periods. If anything, I'd put it down to the box going into a conservative shift mode to try and prevent a high oil temp condition.
    Jun 2016
    Remember, you have lots of air flow on the track (100-200 km/h). Not so much when in traffic...
    Skoda RS 230
    "The Grey Ghost"
    SG-TP-AB RS230 - Timeline
    Sep 2014
    Newtown, NSW
    https://www.google.com.au/search?q=d...in+hot+weather
    It seems to be pretty standard in recent generation VAG models with DSG gearboxes once you get up there temperature wise. I don't think it's anything to worry about unless you'll regularly be driving in 37+°C days.
    Dec 2012
    Sutherland Shire, Sydney
    One of the factors in deciding which gear to use is engine load
    When the inlet air temperatures are high the ECU will be managing fuel mixture and advance differently - likely to have less power - that may force the use of a lower gear
    May 2013
    I'm glad I'm not the only one... I've experienced this happen on several occasions in my Skoda RS on high 30deg days. BTW, the car is only 6 months old.
    Never noticed it on my TDI Golf 7 though...
    Nov 2009
    Quote Originally Posted by Martin View Post
    This won't be an engine load issue; the DSG holds 5th to 70km/h or above with the lightest throttle application, on flat and even declines.
    I'm sure it's not a fault; it's likely to just be a heat management strategy the DSG is employing for whatever reason.
    Jul 2010
    Never had such heat affected issues with my DSG6 (DQ250) in the 5+ years I've owned it.
    Still behaves the same in really cold or really hot temps.
    .....even before I got the DSG tune.
    Nov 2009
    Quote Originally Posted by dArK5HaD0w View Post
    Yep, seems to be unique to the Mk3.
    Nov 2015
    Well it happened again today in Sydney's 40 degree heat. Definitely appears to be a characteristic of the car and programmed into the system.
    Skoda Octavia RS Hatch DSG MY16
    Silver, Black/Tech/Comfort packs
    Sep 2016
    Quote Originally Posted by AdamD View Post
    I've driven literally dozens of DSGs..........The only time I've experienced this behaviour is in the Skoda.................
    It would be interesting to know if this is a specific Skoda programming "feature"..... or perhaps due to physical characteristics of the bodywork?
    ie: no air-cooling being focussed to the gearbox/gearbox-cooler?
    I assume that since they are effectively Golf's in a bigger body, the engine parameters/programming would be almost identical, except maybe some tweaking of shift-points due to heavier weight on the bigger Skodas?
    2016 Skoda Octavia 162TSI RS Wagon
    (Race Blue, DSG, Tech pack, Comfort pack, 18" Black pack, panoramic sunroof, auto tailgate)
    Previous: 2012 Mazda 6 Diesel // 2001 Subaru Liberty STi // 1991 Subaru Liberty RS Turbo // VK Holden Commodore // Subaru Leone // Mazda RX-808 // Mitsubishi Magna // 1971 Mazda R100 Coupe
