the DQ200 is the 7speed dry-clutch DSG, we have a DQ250 6speed wet-clutch.
Printable View
+1.
i was just about to say that.
in the octavia range, i believe only the rs & the scout has the dsg6.
the rest have the dsg7.
most of the issues and vw apologies/recalls r related to the dsg7, not the dsg6.
the dsg6 has its fair share of problems, but nowhere near that compared to the dsg7.
You won't feel it slipping because the computer controls the amount of slip, it is however still slipping, it has to otherwise the motor will stall. Remember that unlike a conventional manual, the entire way that the clutch is working is the complete opposite, there is nothing mechanical holding the clutch, it's an electro hydraulic solenoid allowing fluid into a piston, this piston when a gear is engaged is constantly being adjusted as you speed up from take off to let the clutch slip enough to let you get going without wasting the drive of the motor at the same time. Once required, full pressure pushes the clutch on as hard as possible, then it starts again. You can actually see the clutch slip figures in VCDS as you're driving.
RE DQ designation, yes I know, I forgot I was in a thread about the RS. Trust me, I've enough legal bulltish about these gearboxes over the last 9months I reckon I could pull a dq200 down just as quickly as a trained tech!
Thanks for the heads up Gav - very interesting
All I can say is the DSG works very well during normal usage
(We went for a "enthusiastic" drive today - even in sport mode my DSG was changing up/down frequently, this was not needed imo and it was happening at inconvientient times - for the first time ever I switched to manual!)
77TDI; 103TDI; 125TDI have DSG6
147TSI also has DSG6
90TSI; 118TSI have DSG7. Probably to do with torque figures...
Also - 77TDI has M5!!
