Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
Thread: Downpipe for 2008 VRS TFSI
  1. #41
    Jan 2012
    installation is a piece if piss too BTW. you could probably manage it in a garage with it up on ramps.
  2. #42
    Erskineville, NSW
    Quote Originally Posted by VRSJas View Post
    What's better 100 cell cat or 200 cell cat?
    Thanks
    Based on my armchair, internet research:
    100 cell (per sq inch) cat will flow 2x (?) better but probably chuck a CEL on a stg1 tune.
    200 cell (per sq inch) cat should be error free.
    Keep in mind you're going from a cat with 60mm inlet/outlet & 800 cells sq/i to a 75mm i/o so the flow will be vastly improved if the x-section of the cat is similar.
    When I was enquiring, the one & only exhaust place I rang told me I should get a 100 cell. I told him it would throw a CEL with a Stg1 tune. He didn't know what I was talking about.
    If you are getting a stg2 tune they should be able to write out the CEL error in the programme.
  3. #43
    Nov 2012
    Canberra
    Quote Originally Posted by zei20t View Post
    Thats the whole idea. I managed to do the clutch in my XT Forester on the driveway I reckon I can manage a DP.
    I plan to get mine off then take the whole unit to the exhaust shop get them to put it together and take the new unit bake and fit it.
    Brad: I went with the 200 cel it comes with a bung in it as well for the sensor which I thought would be helpful.
    After doing this I may just stretch it to the stage 2 tune for the little extra.
    Skoda Octavia Vrs 2008 TFSI Race Blue
    | CC Phase 2 tune | BSH PCV revamp | DRL's | HID | LED's | 35% Tints | Towbar |es1099 HU | Rev. Camera | R8 Coils | Brisk LSG Plugs | Adams slotted Fr Rotors | Torque arm insert | 3" Down Pipe | High flow cat |GFB DV+ | VM Shifter Bushes |
  4. #44
    Jan 2012
    smart idea, they can use the old one as a jig.
  5. #45
    Erskineville, NSW
    Yeah, I did my reply before reading the whole thread. I have a (bad) habit of doing that.
    I did my downpipe R&R on front stands in the garage. Easy job. Only 1 nut that is character building - top closest to the block. I loosened it with a Stahwille short ring spanner & spun it off with a 17mm socket on a short 75mm handle 1/4 drive ratchet. It will fight you most of the way off. Lucas reckons you can get at it from the top with an extension. I didn't bother trying as I was making progress & not bleeding so I thought that was pretty good.
    You need to take the white plastic heat shield off the driveshaft (2x 17mm bolts) & the joining sleeve is 2x13mm & the pressed steel crossbrace is 4x 13mm. I started at 14.30 & was finished by 16.30 IIRC but I'm an old ditherer.
  6. #46
    Nov 2012
    Canberra
    Cool thanks for the tips. How do you find the stahwille spaners? Some people love them others hate them. I loved them but my apprencite wage didn't stretch to buying them.
    Sent from my HTC One XL using Tapatalk
  7. #47
    Erskineville, NSW
    I love them. This is my 2nd set.
    I got onto my first set when I asked my tool guy if there was something thin-wall so I could stop grinding doen my 1970s Sidchrome stuff. He showed me Stahwille & they were great. My full toolkit was stolen in 1987 & I replaced it with KingChrome & other various bits & pieces which was OK. This was all stolen again in 1995 and I was off the tools by then so I put together a much smaller tool kit & bought a new set of Stahwille double-ended offset rings in Austria while on holidays (some people buy beer steins as souveniers).
    I love them because they are really versatile, can take a hammering, fit into restricted spaces & they look good. A lot of people don't like how thin the handles are but it's OK with me.
  8. #48
    Nov 2012
    Canberra
    I was amazed by how much of a beating they can take without breaking. I loved the thin handles.
  9. #49
    Erskineville, NSW
    Yep, great stuff.
    I can also highly recommend Bahco sidecutters & Bahco shifting spanners.
  10. #50
    Nov 2012
    Canberra
    I have a pair of side cutters that have lasted me many years of being in the trades. I will have a look at the brand tomorrow. They were very reasonably priced from memory. I did my second apprenticeship as an aircraft engineer so they were used many times a day every day.
