Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 53
Thread: Downpipe for 2008 VRS TFSI
    Nov 2012
    Canberra
    Sorry forget that I just figured it out
    MK5 Jetta 2.0T
    Skoda Octavia Vrs 2008 TFSI Race Blue
    | CC Phase 2 tune | BSH PCV revamp | DRL's | HID | LED's | 35% Tints | Towbar |es1099 HU | Rev. Camera | R8 Coils | Brisk LSG Plugs | Adams slotted Fr Rotors | Torque arm insert | 3" Down Pipe | High flow cat |GFB DV+ | VM Shifter Bushes |
    Nov 2012
    Canberra
    Can I get peoples opinion on this exhaust.
    3" Exhaust Downpipe Down Pipe for VW 06 10 Golf GTI Jetta MKV MK5 2 0T FSI Turbo | eBay
    I realise that its not a brandname pipe.
    Mar 2013
    Brisvagas
    No cat on that ebay pipe.
    Sent from my GT-I9305T using Tapatalk
    Nov 2012
    Canberra
    Yeah I noticed that after I posted it.
    I will keep looking.
    Jan 2012
    that should fit!
    no cat? easy solution. get one fitted in it. or not.
    Jul 2010
    Quote Originally Posted by Tob35 View Post
    +1
    No cat on that one.
    Mar 2013
    Brisvagas
    Most of the ebay DP are catless.
    Pretty easy job for any exhaust shop to weld one in though if thats the direction you want to go.
    Erskineville, NSW
    I can't see how it could fit a Jetta & a GTI unless you have to specify to the seller which vehicle you have.
    Unfortunately, there probably isn't a cheap plug & play solution that has a catcon.
    Cheapest ebay/aliexpress DP is AUD200 delivered. 200cell (100cell will throw an error) catcon is AUD120 delivered (ebay local supplier). You could probably fit the unit yourself at home providing you can just hack the length down to size (2-3hrs work) then drive to the exhaust shop & they can fit the catcon (1hr max) for $100-$150ish.
    So if all the stars align you might get out of it for $420 for a cheap but probably low quality unit.
    The alternative is something good like an SPM with cat for $770 locally.
    42DD with cat from OS is about AUD 620 delivered but I believe the quality isn't great. There's a void of nothingness between those prices.
    Maybe keep an eye out on the forums for something 2nd hand?
    I have a 42dd on my S3 and have fitted a couple myself to mk6 and late model A3s. They aren't stainless but I wouldn't say the quality isn't great at all.
    Mine is 2 years old now and looks pretty much as it did when it was fitted. I certainly expect it to last the life of the car.
    Erskineville, NSW
    I mean fitment quality - it sounds like it might be a bit variable. Was considering one myself but was put off from the number of instances I found of people saying they weren't terrific. I think if you are going to spend that type of money you may as well spend a bit more & get something that hasn't had any bad reviews.
    If you say that you haven't had issues with several installs then that's worth taking on board as well.
