Results 1 to 10 of 10
Thread: Display todays date in MFD or RNS510?
    Melbourne, Vic
    Does anyone know if today's date can be displayed on the RNS510 or the MFD anywhere? Does it need to be turned on via vcds?
    My A3 and A4 have the time and date in the bottom of the tacho dial. A3 also has on the radio (Symphony), but I cannot find anywhere to display today's date in an Octavia RS. (aside from where you set it on the RNS510)
    Dont ask why I need it, I just want it on.
    2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
    2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
    2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
    2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
    Apr 2010
    In the HU setup you can enter the date and time, but I've never seen the date displayed anywhere.
    Melbourne, Vic
    I have set the date, but to drill down menus to see what the date is is a pain.
    Oct 2009
    Mitchelton, Qld
    If you set the date in the MFD, but can never see it displayed anywhere, then what is the point of the date setting? Is it so any fault codes etc can be date stamped?
    Jun 2009
    Quote Originally Posted by donweather View Post
    Probably helps with the yearly service reminder
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by team_v View Post
    Ah yes, good point. Had forgotten about that.
    Jul 2013
    NSW
    When I set the date on my RNS510 (latest maps & firmware) all goes well, but when I switch the car off & on again the unit resets the date to the default again.
    DISREGARD, I have fixed this issue.
    If you set the date whilst in a forest, but nobody saw you go into the forest, did you really set the date??
    I've not come across a way to easily display it either other than going down through the MFD menu functions. I just check my phone if I wake up and don't know if I should be going to work or not...
    Adelaide hills, SA
    I always know what day it is, but the date gets forgotten sometimes.
    It could be quite handy to have it displayed.
    Bowral, NSW
    Sig'd.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
