Results 1 to 10 of 13
Thread: Dash Cam Power Supply installation.
    Sep 2015
    Hi,
    I have a 2016 RS and have installed a dash cam but as the assessor plugs do not turn off when the car is turned off, have to take out the plug when the car is turned off.
    My questions is, has anyone else installed a dash cam or similar device needing the lighter power socket and did you find another way to hard wire it in so that it was not on constant supply of power?
    Thanks...
    Feb 2014
    Geelong, Victoria
    Have a read here. The post covers various options for you and/or an auto electrician to install a permanent fixture
    Cheers Fred
    Dash Cam & 12V Multi Adaptor Hidden Install (driver storage compartment) - Skoda Octavia II (2004 - 2013) - BRISKODA
    MY13 VRS Octavia Wagon, 2.0 TSI, DSG. Platin Grey
    Pacific Paradise QLD
    You can do it neater and easier than that by buying one of these ciggy sockets and hooking it to an addafuse as in the thread.
    Run the camera end of the cable from inside the fuse box area to the weatherseal and up to the camera tuck the excess inside the dash and wrap it all in bubble wrap to stop rattles
    Attached are some pics of two of my installs in a Polo and a Passat which has front and rear cameras In the one thats cream you can see the camera cable going up to the right and is hidden when end panel is fitted. I cut a small nick out so it didnt crimp it Same with the Polo one.
    The fuses i used are in spare powered sockets and come from Jaycar with the wires attached
    Dont cut the ciggy plug off the cameras as they have a 2 amp fuse in them usually The Dual lock tape is what I attach my Blackvue cameras to the windscreen with Havent had one fall off in 3 years of temps from -5 to +40
    Sep 2015
    This info is exactly what I was after. Thank you very much guys....
    Oct 2010
    You can also get a fuse tap to something that is powered by accessories, rather than power. It's much neater than one of those cigarette lighter sockets.
    2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
    Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
    Quote Originally Posted by GTR27 View Post
    Like these BUT as the fuse for the camera is in the ciggy plug its best to use that and also it means you can take the camera out and use it another car.
    Been there done that on overseas trips. I have a spare power lead that I use for that
    If you use the addafuse on the left make sure you put it in the correct way as it only works properly one way.
    Have installed 7 cameras altogether quite sucessfully and neatly so you cant tell the wiring is there I did use a multi ciggy socket overseas so I could run a nav ,camera and charge phones at the same time but a bit untidy
    Sep 2015
    After a quick visit to Jay Car today, I have as per suggestions installed the dash cam with the use of an add fuse and a cigarette socket, the dash cam now turns off and on with the car and not just stay on.
    Total Cost: $16.00 inc 5A blade fuse.
    Thank you all for your assistance with this. Would have saved me will over $100-200 in auto electrican costs.
    Quote Originally Posted by AVJ View Post
    Just make sure you put the addafuse in the correct way It goes in with the wire pointing down usually as if you put it in the other way the fuses wont work as fuses What I mean is you put the Addafuse in with the wired side to the cold side of your fuse that you replace so that the power comes in the other pin and through the fuses to the car.
    As per this link from 2013 DIY Blackvue DR400G-HD/Power Magic Pro Dashcam - Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB
    These are the brand I install except it is an older model now but all else applies.
    The Power Magic enables it to stay on for a selected time when parked and has a low voltage cutout so it doesnt run the battery flat
    Dec 2006
    Kilsyth, VIC
    I've used those blade fuse wiring things in the past but have put the extra wire on the hot side (and added an inline fuse to that line) so I wasn't attempting to add extra draw across an existing fuse.
    Did you get the type that are hard wired or the ones like this with have a socket on the back?
    Double Blade Fuse Socket Wire Tap | Automotive Blade Fuses & Holders | Circuit Protection | Passive Components | PRODUCTS | SF5115 | Jaycar Electronics
    The only reason I ask is that if you've gone the hard wired route you need to remember to keep a spare in case it ever blows, the one with the socket of course uses your standard replacement fuses.
    Quote Originally Posted by The_Hawk View Post
    Using the one in your link you have the left side in the hot side of the fuse socket and the current flows through both fuses as normal If you fit it back to front it goes through the bottom fuse and then to the extra fuse so you have effectively got the load of both on the "original" fuse.
    Using the little one in my pic, if you use the 10amp one it doesnt really matter as if you also use the ciggy socket the camera plug has a 2 amp fuse in it which will blow long before the 10 amp one does.
    I dont know why you would add another wire as if you want to put a line fuse in you could have just put it in with the wire on the hot side and take it off that and the internal fuse would work as normal.
    In the VW it has plenty of unused fuse sockets with both always on and Acc power so I just stick one in there and there is nothing else on the circuit anyway
    Attached is pic of what I mean Excuse the bad drawing LOL
