The car requires a change into 3rd gear at about 95kph, so the time difference is likely the change into 3rd to hit 100kph.
The bit I noticed is that there's 0.3s difference between 0-60mph & 0-100kph. 100k is 62.1mph. 0.3 seems a long time to gain 2.1mph relative to the overall acceleration. Or am I just effed in the head?
Oic
1234567
i didn't cover a 1/4 mile doing those runs. i backed off as soon as i hit 110-ish km/h.
neither did i take note of the gear changes. next time i'll take note.
regarding the hp reading at 4.8k rpm surpirsed me too. it was still pulling hard heading into the 6k rpms.
according to torque-pro, the best way to accurate hp & torque, is to "start from a slow rolling start (about 8 kmph to 15 kmph) and accelerate until about 88 kmph. This will give you the most accurate peak value for your vehicle."
maybe a few more runs to get a more accurate measure.
i wonder if its possible to download & analyse the logs of the torque pro tool.
MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
finally....after an initial false start and a few weeks later - the dsg tune is in!!
just when I thought I couldn't smile any more cheek to cheek.....oh boy!! even the mechanic at cvvwc had a big grin after taking it for a test drive after writing the dsg tune!! and he's done a few dozen GTIs.
the gear changes r noticeably quicker. drive mode is less reluctant to hurry into 6th. sport mode is the biggest difference - its now enjoyable!!
rather than a screaming lunatic, it sounds like a predator hunting down its prey!!!!
phwoaarrrr!
here's what the DSG performance tune does:-
- Modified torque limiter & torque capacity upgrade 450 – 500nm
- Modified D - Drive mode for better drivability (gear closely matched to engine load & vehicle speed)
- The S - Sport program is "lowered" for better usability
- Faster shift response (especially for the older models)
- All new software is based on the newest VAG version
- Clutch shudder is dramatically reduced
- Longer life of gearbox & clutch packs, less clutch slip
hmmm tempting
actually im tempted to get a dyno tune and DSG tune all at once........... just need to find some cash
2012 Yeti 77TSI, Candy White
ydad.com.au: musings of a dad growing up - the blog.
cbay.com.au: photography, video, design - creations.
im not canberraian so roundabouts don't have the effect on me
however, I see your point!
need to sort out my superchips tune issue, and then ill think about the DSG tune.
