Results 21 to 30 of 35
Thread: Custom downpipe for Octavia VRS Melbourne?
  1. #21
    Jul 2010
    Re: Custom downpipe for Octavia VRS Melbourne?
    Quote Originally Posted by andymarc View Post
    So the Jetta Exhaust will fit an octy?
    That's what I've been told by the folks at apr.
    Same length, piping & route.
    I'll know for sure when it gets installed trow.
  2. #22
    Point Cook, Vic
    The APR one gets trimmed to size during the fitting process unless they are pre-trimming them before shipment.
    It also has an adjustable hanger so suits the slightly different path it needs to take.
  3. #23
    Jul 2010
    Quote Originally Posted by Tim View Post
    as previously stated - same length, piping & route with a mk5 jetta gli.
    had mine installed today. there was no need to trim or adjust
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  4. #24
    Point Cook, Vic
    I didnt see the post above.
    If you fit the entire turbo back then its a direct bolt on. If you just go the DP route then it needs to be trimmed to length to mate up with the stock Octavia cat back
  5. #25
    Jul 2013
    Caulfield, VIC
    2006 2009 Audi VW Golf GTI A3 2 0T Jetta Gli MKV M2 Turbo Down Pipe | eBay
    Was looking in to the above one as well, shot off a proper postage quote. Although this one doesn't look like it has the lower o2 sensor, it does state there are two in the ad.
    Stupid questions:
    -I cant see the higher one from having a quick look under and up with a jack. Are there two sensors?
    -If theres only 1 sensor, would the DP come with a fitment to block the other hole?
    -The ones we've been looking at are 'de-cat'. Does the VRS come with one cat or two. I thought the two rear muffler boxes are just mufflers..
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
  6. #26
    Jul 2010
    Quote Originally Posted by MountainBikeMike View Post
    2 sensors - yes.
    vrs stock downpipe comes with 2 cats. the 1st one between primary 02 sensor port and the flex coupler, and the 2nd, as shown in the pic below.
  7. #27
    Oct 2009
    Mitchelton, Qld
    How come the APR website has the same part number for the Occy as the Golf GTI if according to the above the GTI is too long for the Occy? APR also confirmed the Golf GTI MK6 downpipe will fit the Occy MK2. I'm confused by the above stating things need to be trimmed for the Occy?
  8. #28
    Erskineville, NSW
    APR probably assume you are using the APR catback from the Jetta.
  9. #29
    Jul 2010
    Quote Originally Posted by donweather View Post
    not sure, maybe its to do with the position of where the apr downpipe ends up with respect to the stock octavia catback.
    the golf catback is entirely different design to the octavia catback.
    when i got the full apr exhaust, for a jetta, there was no cutting/trimming required.
  10. #30
    Dec 2012
    Sutherland Shire, Sydney
    I'm using the APR hiflow CAT and downpipe from the Jetta - into the stock Octavia CAT back exhaust system
