Results 11 to 20 of 21
Thread: Columbus Nav question
    Jul 2010
    I updated my firmware from 27xx to 40xx with no fuss.
    My available storage for music grew from 20gb to 33gb.
    Got some nifty little features & enabled personal POIs.
    Sep 2009
    Quote Originally Posted by dArK5HaD0w View Post
    That is strange. The original drive was 30 GB with two partitions one at 10GB for map data and one at 20 GB for music. Either you have a 30 GB drive and now no partition for data or the drive is bigger than the originally advertised 30GB which is more likely.
    My Škoda photos here
    Flickr : Blog
    Apr 2010
    Our custom firmware images have been modified so that the music partition is 90% of the HDD instead of the default 75% or whatever it is, since our map data is smaller than Europe.
    Jul 2010
    Quote Originally Posted by K1W1 View Post
    that's exactly wat i thought too - cause the brochure said "30gb" hdd.
    however as it turns out, i have a 40gb hdd. don't know if it changed with my11 or half-way through.
    here is link to post of where i discussed this earlier.
    here is a pic after the firmware update. this is after loading the v5 maps on to the hdd.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Aug 2012
    Funny after my upgrade yesterday I couldn't even see this menu you're showing.
    Also it stuffed up a lot of things in my car:
    - My navigation didn't show up in the MFD anymore
    - My steeringwheel controls didn't work
    - When I started the car this morning, everything worked again but the steeringwheel controls were all over the place :-S
    Sep 2009
    A 40GB hard drive is much more logical. Today they are probably a 200GB drive just formatted smaller because you can't buy drives as small as 40GB any more afaik.
    I wonder if anybody has tried replacing the drive with a larger unit? I assume it's just a standard 2.5" drive.
    Flickr : Blog
    Apr 2010
    Normal HDDs wouldn't last very long in a car if they're operating with all the bumps and G forces. The extra protection makes them slower and more expensive, hence the smaller size. The exception to this rule are SSDs which would be an idea replacement.
    Aug 2012
    After doing this update (4024) I got a lot of problems:
    - My steeringwheel controls were all over the place
    - My Nav started working in the MFD again, but I kept the problems with the controls not working
    So I decided to bring it back to Skoda today and let them sort it out.
    Well I got the solution (I hope) of why my steering wheel controls are not working properly.
    Skoda advised me today that it's a faulty Clockspring. They've done a full search of any faults in my car, and they came back with this solution that it needs to be replaced. They started off with the software diagnoses and then pulled my dash apart to investigate further as the software showed up there was no issue what so ever.
    I'm pretty p****d off about it since my car is only 4 days old. So they gave me the car back today and I need to bring it back on Monday once the new clockspring has arrived from the warehouse.
    So yeah this was the bad news for now
    Sep 2009
    A normal hard drive will work perfectly fine in the dash board area of a car which is the most stable area. A little bit of silicon based foam or similar around it to protect against shock and it will last as long as the car itself. If you think that there is some sort of magic special hard drive in your Columbus think again.
    There are countless hard drives mounted into all sort of vehicles everything from data recorders to media players to computers and they all generally work perfectly well. The hard drive in a school kids notebook in their school bag will suffer more shock stress than a hard drive in a car radio system.
    My mark 2 iPod circa 2004 with its 40GB hard drive has been in the dash and centre console of cars almost it's entire life and it still works perfectly ( except the battery).
    Flickr : Blog
    Bowral, NSW
    The 40GB HD is more shock-resistant than your average 2.5" HD. Smaller capacity, but built for automotive.
    More tolerance towards temperature and vibration.
    I wouldn't run a normal HD in the Columbus unit, no way in hell.
    The HD in school kids netbooks aren't running whilst they're being thrown around, AND they're not designed to last the life of the vehicle...
    Imagine if they just used consumer grade stuff??
    6 months after you buy the car, the HD dies. Rinse, repeat.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
