Results 1 to 10 of 12
Thread: changing VRS wheels for comfort
    Oct 2012
    Augustine Heights, QLD
    Hi Guys,
    I know this goes against everything I believe in but looking at changing the stock VRS wheels to a set of 16s to soften the ride. Has anyone done this or got any experience on how big of a difference this will make?
    Other than not looking as cool does it have adverse effects on anything else? I would imagine a bit more body roll on corners?
    Cheers!
    Jul 2014
    16's won't fit over your massively big rotors.
    You will have to go at least 17's.
    Oct 2010
    Melbourne, VIC
    See Reducing rim size on vRS
    Body roll will not increase by any noticable amount. Steering may be a touch less responsive. Ride will improve massively and grip may well improve on bumpy roads.
    If you haven't gone BBK, they'll fit
    Resident grumpy old fart
    Jul 2014
    Sorry was thinking of Mk3 vRS.
    Oct 2012
    Quote Originally Posted by Gerrycan View Post
    Awesome thanks guys, so the rotors on the Mk2 will fit over 16s fine?
    Oct 2010
    Melbourne, VIC
    Did you read through the other thread I linked?
    Oct 2012
    Quote Originally Posted by kaanage View Post
    Actually reading it now, thanks
    I wouldn't go smaller than 17" wheels personally. I think 16" wheels will look a bit silly on the vRS.
    The 17" wheels will still give a nice comfy ride with a good range of well priced tyres and a nice sidewall depth to give a compromise between looks, handling and comfort.
    Although if you are hell-bent on getting 16" wheels, here are some off another Skoda for sale in QLD: 4x Skoda Octavia 16inch alloys w/ Toyo NanoEnergy 3 tyres
    Oct 2012
    Hi Lucas,
    I hear what you're saying about looks wise but honestly at the moment the ride factor is much more important as I'm taking a lot of clients around and the harsh ride over dodgy inner city brisbane streets is not a nice experience for them.
    I'll be keeping the 18s to put back on in a few months once that is no longer necessary. I am actually purchasing those ones you linked already. Just for the tyres alone while I'm smashing the k's for the next 3-6 months it will be well worth it.
    Thanks.
    Erskineville, NSW
    Quote Originally Posted by Aztech View Post
    Hi Guys,
    Cheers!
    16" fit fine on 312mm rotors. Ideally, find some A4 Audi rims which are 16x7.5 ET50 and have 225/55r16 tyres. They are cheap as chips - you almost can't give them away.
    If you run 205/55r16 it will look under-tyred even though that's the OEM size
    There's about 10mm clearance between the rotor & the rim
