Originally Posted by
Smiley_Walsh
Hi,
Have you got any advice when looking at a vRS manual Octavia? I'm also looking at a 2007 with around 100,000 kms.
How much should I pay?
Should timing belt be changed at 105,000 kms, as I believe?
Anything to look out for when test driving / inspecting?
I'd consider having it inspected and may call Camden GTI in Campbeltown to discuss service needs.
It's pretty clean and straight. Has decent tyres and brakes all round. Gearbox seems good.
Any personal advice you can give from experience is appreciated!
Thanks.
Timing belt, water pump & pullies should have been done or will need doing ASAP.
Look for a full service history of oil/filter changes at least every 15k/12m.
Make sure the AC is icy cold & work s on both sides - this model had an unreliable compressor.
Have a good look at the suspension, esp the rear console bushes on the front lower control arms. The dampers will be shot by now so count on doing something there in the near future and also getting a quality wheel alignment.
look for corrosion / damage in the sills and if it's a hatch on the join line on the vertical part of the boot (just below the badges).
A sedan will be about $9k with no money needed to spend, wagon about $10k.
edit: Lucas gives some good advice there
