if it's in Giraween the get Seb at Euromotive to have a look - he's a very knowledgeable VW specialist and would know a lot more specifics than a State Roads guy who has to be a generalist by neccesity.
Thanks. I called Seb. He's overseas atm unfortunately!
State Roads report was quite positive. A good bloke called Michael, who appeared very familiar with Skoda / VW. Some minor fixes required which the dealer will see to before sale:
Worn nearside rear tyre on inner. Michael thought most likely to be from a misaligned front tyre swapped to the rear (any thoughts / suggestions about this?).
Brake bulb replacement n/s rear
small oil leak from oil filter only, tighten or replace
headlight mounting broken, front left - repair required
Left rear passenger window motor connected in reverse - fix
Otherwise, he noted that the clutch is good - estimated 60% worn. Brake rotors and pads recently replaced.
No significant bodywork issues - there have been some professional repairs. Structurally sound. Aircon icy-cold. Gearbox good. All onboard electronics working. Wiper blades need replacement!
This is my own summary of our discussion - not his actual report, obviously!
So, assuming my finance comes through and the agreed items are fixed by the dealer, I'll soon be the new owner.. 👍🏼
ill be be planning to have a wheel alignment done, and to replace filters (oil, air, pollen, fuel) plus PCV and the diverter valve. - thanks for advice regarding all those. Probably a thorough valet too. 😀
My 08 Octavia vRS is 220'000 and still kicking! Changed the timing belt and water pump at around 180'000 and the mechanic said the belt 'ok' for the kms it had before changing it... Do regular oil changes and you'll be right... The belt had been changed at 80'000 before I bought it (or say it says in the log books)
MY13GOLF2.0GTI/6SPDMAN/CARBONSTEEL
MY15TIGUAN2.0TSI/DSG/WHITE
I forgot, I replaced all shocks (after popping one on a pot hole) at 150'000 and added a sway bar...
Good to know! Hope mine lasts as well as yours, boogz!
The dealer has agreed to replace the n/s rear tyre, fix the oil filter leak and left brake light, and they will repair the missing/broken headlight mounting and remedy the reversed n/s rear window operation - all before I collect it.
I'll certainly arrange a 4 wheel alignment and sort the wiper blades myself! Plus the suggested part replacements suggested previously (filters, PCV & Diverter valves).
