Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Buy a used Octavia.
  1. #21
    Oct 2013
    Camden, NSW
    If that is the case, loose shaft, the car still has over 6 months warranty. Id like to think that would be covered. Thanks for the heads up ill check it out.
  2. #22
    Jan 2013
    Preston, VIC
    Quote Originally Posted by wfdTamar View Post
    One thing to look for is about 10mm play in the steering wheel. Caused by looseness in the shaft at the bottom of the steering column. Only official fix is a new column at $960 plus fitting! I had this on a 67,000km car.
    That's seriously low mileage to present a problemo like that, wfd. And 7k out of warranty too? Any clues as to the cause? Bad case hardening on the rack or pinion?
  3. #23
    Gosford Central Coast NSW
    Quote Originally Posted by Skooter View Post
    Theres a polymer bushing in the shaft that has a known early life failure on some units. Its not very common but its been documented elsewhere.
    must have been the production run of one set of bushings.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
