Results 21 to 30 of 34
Thread: Brake wear
  1. #21
    Feb 2009
    NSW
    Why should we avoid drilled rotors?
    Sent from my SM-G930F using Tapatalk
  2. #22
    Aug 2016
    Quote Originally Posted by ozgti View Post
    https://www.youtube.com/watch?v=78wbht355R8
    MY16.5 Octavia RS wagon, manual, Moon White + tech pack + 18" black pack.
  3. #23
    They are more likely to crack (hairline cracks around the drilled holes)
  4. #24
    Erskineville, NSW
    The drilling process sets up stresses in the metal which lead to hairline cracks radiating from the drill holes.
    if the holes are part of the forging process and stress relieved after maching, they are OK.
  5. #25
    Dec 2008
    Sydney/Canberra
    The holes can also fill with brake dust, causing hotspots which lead to cracking.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  6. #26
    Nov 2009
    Illawarra NSW
    Every motorcycle I've had has had drilled rotors. They have done track days, been subjected to greater braking forces than most cars and never had an issue. I'm calling "male cow faeces" on this one.
    2014 MY14 Corrida Red Elegance Wagon TDI
    2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
    2011 MY12 Yeti 77 TSI DSG.
  7. #27
    Dec 2008
    Sydney/Canberra
    Bike brakes are out there in the open air.
    Car brakes are more suceptable to heatsoak, and a general lack of ventilation when you push them beyond their capabilities.
    '01 Beetle 2.0
  8. #28
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    Quote Originally Posted by donweather View Post
    Wow you guys must be hard on brakes. I've done 93k and still on first set of pads and rotors and still have plenty left according to my mechanic. But I have a manual and so I change down a lot instead of braking a lot of the time.
    They must be all city drivers wasting their lives in traffic , still have original front brakes with 180,000 km , rears replaced at 160,000km.
  9. #29
    Erskineville, NSW
    Quote Originally Posted by Antiplastix View Post
    Do what you want.
    Motorcycle brakes are generally much thinner, solid (rather than vented), floating and a different metallurgy to car rotors. Motorcycle rotors are generally dealing with ~150-300kg of mass, rather than 1000kg-2000kg.
    As I said, if the holes are cast/forged in place and stress relieved (like on a Porsche) they are fine. If they are machined (drilled) then not so great although for looks and general bopping about the suburbs they are fine.
    Google it.
  10. #30
    Dec 2012
    Sutherland Shire, Sydney
    DBA (Oz brake company) even mention the problem in this article:
    Rotor Damage | Basic Guide Pt 2 - Disc Brakes Australia
    Quote Originally Posted by DBA - Rotor Damage
    3. Brake Rotor Cracking
    When cracking occurs, its practically the end of your disc brake rotors.
    While drilled rotors offer loads of performance braking improvements, they are also more prone to cracking.
