Why should we avoid drilled rotors?
Sent from my SM-G930F using Tapatalk
Printable View
The holes can also fill with brake dust, causing hotspots which lead to cracking.
Every motorcycle I've had has had drilled rotors. They have done track days, been subjected to greater braking forces than most cars and never had an issue. I'm calling "male cow faeces" on this one.
Bike brakes are out there in the open air.
Car brakes are more suceptable to heatsoak, and a general lack of ventilation when you push them beyond their capabilities.
Do what you want.
Motorcycle brakes are generally much thinner, solid (rather than vented), floating and a different metallurgy to car rotors. Motorcycle rotors are generally dealing with ~150-300kg of mass, rather than 1000kg-2000kg.
As I said, if the holes are cast/forged in place and stress relieved (like on a Porsche) they are fine. If they are machined (drilled) then not so great although for looks and general bopping about the suburbs they are fine.
Google it.
DBA (Oz brake company) even mention the problem in this article:
Rotor Damage | Basic Guide Pt 2 - Disc Brakes Australia
Quote:
Originally Posted by DBA - Rotor Damage
