Page 6 of 11 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 106
Thread: Bluefined my 2012 VRS Octy
  1. #51
    Erskineville, NSW
    Quote Originally Posted by donweather View Post
    John, one further question if I may please.
    Based on the above, my ECU is currently adapting to the intricacies of my engine specifics such as small variations in compression etc. If I were to then install some R8 coil packs at some stage in the future (and presumably this may change the small intricacies of my engine) will the ECU (and presumably the bluefin tune) re-learn and adapt to this new engine specifics in the future also?
    I'll pre-empt & say yes but I look forward to the response.
  2. #52
    Nov 2009
    Illawarra NSW
    Unless your car is currently misfiring , why bother with the R8 coil packs. The only thing that will have to adapt is your biceps from lifting the bonnet to check out your extra red paint.
    2014 MY14 Corrida Red Elegance Wagon TDI
    2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
    2011 MY12 Yeti 77 TSI DSG.
  3. #53
    Erskineville, NSW
    Stronger spark because there are more windings.
    It's very likely that you'll get a coil pack failure after a remap. For the $140 a set of R8 coilpacks cost it's cheap maintenance & then you have a set of stockers for spares.
    You can't actually see the coils as the engine cover is in the way.
  4. #54
    Oct 2009
    Mitchelton, Qld
    Yep exactly what Brad said.
  5. #55
    Erskineville, NSW
    I can assure you taht as a Skoda owner I do very little to my car "just because it looks good". This would be like putting lipstick on a pig - delusional for the owner & embarrassing for the pig.
  6. #56
    Oct 2009
    Mitchelton, Qld
    Man I'm loving these cool autumn evenings/mornings!!! Car feels like she's pulling an extra 10kW!!!!
  7. #57
    Jan 2013
    Just wondering, did you have to get the conversion kit in order to fit the 2.0t coil pack due to size difference? I was looking into this and they say you need a spacer of sorts for the 1.8tsi?
    Sent from my GT-N7100 using Tapatalk
  8. #58
    Erskineville, NSW
    Quote Originally Posted by NOO63N View Post
    Nope
    I'm pretty sure I eyeballed the dimensions & they were the same. Just bunged them in
  9. #59
    Jan 2013
    Nope
    Ah okay sounds good. Were they these ones?
    Coil Pack
    Edit: with this part number? 06E905115E
  10. #60
    Erskineville, NSW
    Checked the box - yes. That part# 06E905115E
    BTW: catcon mod gave me a cell yesterday. It recorded 8x out of range. It appears it needs x numer of counts before recording a CEL.
    I deleted it with VCDS
