Page 9 of 11 FirstFirst ... 7891011 LastLast
Results 81 to 90 of 106
Thread: Bluefined my 2012 VRS Octy
  1. #81
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by donweather View Post
    Some impressive figures coming out of the APR Stage 1 on the new golf 7 GTI.
    APR tune released 316hp and 380tq. For those of us more metrically-minded, those figures are 235kw and 516Nm at the fly, on 98 RON. WHOA.
    That is impressive, it just keeps getting better...
  2. #82
    Jul 2010
    Is this the same engine that's in the occy 3 rs?
    Yup....exact same engine.
    And unlike with the mk2 vRS, they haven't detuned it for the mk3 vRS.
    Yipee.
  3. #83
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by dArK5HaD0w View Post
    Yipee.
    Haven't detuned it as stock? I thought the Mk3 RS was only 162kW stock?
    Those APR figures are mind blowing, but again, FWD is gonna be a tough ask to push all that power through.
  4. #84
    Erskineville, NSW
    Mk2 vRS was always 5kw less than the equivalent GTI. Mk3 appears to have equal power to GTI.
  5. #85
    Aug 2013
    I have recently finished my exhaust so I now have a full 3" TBE... Spoke to John @ Tigersoft again as I was having a few little teething issues but after the latest tune, things appear to be alooottt smoother.... Very happy...
    Can definitely recommend getting in touch with John @ Tigersoft if your looking at bluefin as his service is second to none... Also has a quality dog to play with if you ever visit him...
  6. #86
    Oct 2009
    Mitchelton, Qld
    Have noticed recently my bluefinned RS appears to be lacking some grunt down low in 2nd gear. Just doesn't seem to have the push you back into the seat that it used to have down low in 2nd gear. Could this just be the warmer weather in Qld now? Or something else with the remap/engine?
  7. #87
    Jan 2012
    its probably a combination of you getting used to it, and the weather warming up.
  8. #88
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by zei20t View Post
    Whilst I might be getting used it it, the car def doesn't pull as hard....noticeably less torque steer in low 2nd....so it's not just me getting used to it.
    I have a question. It appears to have occured around the same time as I got my LCA's fixed. Could the place where I got my LCA's fixed have also reset my ECU back to stock or detuned it somewhat? (No it wasn't a dealer....just a VAG and other Euro car mechanic place).
  9. #89
    Erskineville, NSW
    No reason to disconnect battery even if it was the most cautious mech in the world. Even battery disconnect doesn't remove the tune.
    You wouldn't be getting sticky vains in the turbo would you?
  10. #90
    Jul 2014
    Dtuk Vrs Octavia
    Hi Guys,
    Sorry to hi jack but I think it's some what relevant, I recently installed DTuk on my TDI Vrs and have put to map 3.+2.
    Do you guys that have a tune gone on limp mode before? Over last week I had this issue where while I was driving and gave full throttle on the move to over take and yellow flashing sign appears on the dash(not ASC/traction control). Immediately felt the car was not accelerating while i step on the gas pedal seems like limp mode. Car works fines still can drive but it is as if turbo was switched off. The error code disappears when I switched the car off and on back.
    Anyone have this experience?
