Your assumption is correct. It's an easy retrofit however.
Sent from my HTC One_M8 using Tapatalk
Ive just got myself a 2010 Octavia VRS with the Columbus head unit.
When I tried to sync my Iphone 5 nothing happened.
I tap the Phone button on the head unit and it either pauses or/and mutes what ever is being used at the time.
Same with the Phone button on the Steering wheel.
Im currently assuming that I simply dont have bluetooth fitted.
Any tips or hints would be a real help.
Any brand in particular?
Oem is the only choice I can recommend. All others have shortcomings. Where are you located?
SYD eastern suburbs. I keep seeing Fiscon being recommended. Does the OEM provide full function?
I don't know anyone with a Fiscon who is happy with it. OEM stands for Original Equipment Manufacturer. It means same as factory.
Pm me if you want some help sorting it out.
I thought bluetooth was standard in the vRS/columbus? Is that not the case?
Nope. Mine came with an aftermarket install from dealer.
