Thanks guys - they are awesome in looks and brake feel - more pictures to come
![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Martin
The calipers, brake pads, mounting plate and bolts weight 4.2kg (heavier than it feels)
The rotors weight 9.2kg (lighter than they look/feel)
That seems like a good weight for the rotors considering their diameter and thickness
Ok, brace yourself, here is the surprise of the day!!!
The original Skoda (VW) calipers, mounting bracket and pads weighted in at 6.5kg
Good grief Charlie brown - a huge 6 piston caliper is 65% of the weight of the stock single piston caliper!!
(Now I understand why everybody goes on about the weight penalty of using the R32 front calipers)
Now, the rotors:
Those massive HPA rotors are a fearsome lump of metal to hold (for a very short period of time!)
They are the sort of thing a Scott would lug around the moors on each arm when walking into battle (glup).
Drum roll please...
HPA two piece rotor 355mm 32mm thick weighting in at 9.2kg
Stock Skoda (VW) is 312mm diameter and 25mm thick weighting in at 8.5kg!!!
So the all up weight per side is 15kg for the Stock Skoda setup and 13.4kg for the HPA massive brake kit
Clearly the HPA caliper weight and the two piece HPA rotor is what achieved this result
(One piece rotors always have a large weight penalty)
I really did not expect that - it's quite astounding in my view
