I found this very useful post regarding piston size on a UK forum:
Originally Posted by Prawn
Each caliper has three pistons on each side of the rotor disc
2 * 28mm & 2 * 31mm & 2 * 35mm (approximately)
In total this will be a lot more surface area than stock for sure
Normally with bigger pistons you would get a longer peddle, better feel and need to use less force
I'm guessing the smaller pistons are trying to reduce this effect - they should kick in fairly quickly
More than double.Originally Posted by Martin
To my knowlegde the reason for the dissimilar piston sizes is for even wear across the pad.Originally Posted by Martin
You may find that the rears actually come on faster and under hard braking may even trigger the ABS on the rear.
If you have high temp pads you may find it a bit interesting when they are cold pulling up at the first set of lights.
IMO a BBK is great on a track hack if set up correctly with the right master cylinder and bias valve. Not so great simply bolted onto your road car.
The kit comes with ceramic pads intended for (heavy) street usage but can handle (limited lap) track work
They are Corvette pads - huge area on them
Should be fine even when cold...
I've been measuring these HPA brakes and my wheels to see if the installation is likely to be successful
I'm only concerned about calliper clearance to the wheel spokes - all other mechanical aspects are fine
I can see why these will fit under stock wheels - it's because of the large rotor diameter - that pushes the calliper further away from the hub and wheel centre - there is more clearance to the wheels spokes out there
I also discovered that my Audi RS4 wheels have much more clearance than the Skoda Neptunes (which are sold) and the Golf R wheels - they are my backup plan if things to get too tight (need 3mm clearance)
I also placed a rotor inside a bare 18" wheel to see what it looks like - our 18" wheels do tend to dwarf our stock 312mm brakes, but it's completely different with these 355mm rotors which fill 80% of the interior wheel diameter
Our VRS rotors are 25~26mm thick - these HPA rotors are 32mm thick
Now on paper that does not sound like much - although mathematically it's 23% thicker
However, holding these big HPA rotors is quite intimidating - they are a massive lump of very thick steel
I may have to see if I can weight stuff - the stock brake parts and the HPA components
The HPA callipers are clearly very light, despite being physically massive they are not at all heavy
The rotors weight a ton, I would expect tears if I dropped one on my foot
I'm very tempted to throw some DS2500 pads in the rear
(can't find the Ferodo DS2500 part number for the 1Z4)
Any suggestions as to what brake fluid to use?
Now I understand - the leading edge may bite harder than the trailing edge - thanks
I agree in principle
The VRS has a bigger master cylinder than the normal models - that's why its brakes currently feel over powered around town
There are numerous big brake kits designed for the Audi/Golf/Skoda platform - people that do purchase them are very happy with the performance and feel
Yes, have to agree, I guess the question is what was the claimed weight saving compared to?
If they were comparing to R32 brakes - maybe...
The calipers, brake pads, mounting plate and bolts weight 4.2kg (heavier than it feels)
The rotors weight 9.2kg (lighter than they look/feel)
That seems like a good weight for the rotors considering their diameter and thickness
could be right there, so they are not quoting that saving based on a mk VI / octavia?
The calipers and mounting hardware are pretty light for what they are, I'd guess that stock calipers would be more than 4.2kg each.The calipers, brake pads, mounting plate and bolts weight 4.2kg (heavier than it feels)
