When you have this amazeballs setup installed, mind if I see if my 18x7.5 rims will fit around it??
If so, I'll join you with this kit.
Just need to find something to upgrade the back with...
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
Yes, no worries at all, it's all about spoke clearance
These are the black wheels currently on your Octavia?
Awesome! That will put 3 of us in the Octavia Big Brake team (Todd, me and you)
Given cost versus benefit, I would say keep it simple and much cheaper
I'm going to put some Ferodo DS2500 pads in the rear and see how that goes
If needed the next upgrade step after that is to install R32 rear brakes
Due to the handbrake, your options are few and far between
One guy in the USA made a dual caliper hub for the rear
He uses a big fancy caliper for braking while driving and tiny caliper on the other side for the handbrake
Yup!!
I was thinking just put the old Octy front disk/calipers on the rear... But I didn't realise about the handbrake!! :/
What is your OEM brake wear like?... I know my pads (upon dealer inspection) have 10mm left!!!... That was at the 60,000km service...
R32 rear brakes are blue, aren't they?... Need caliper paint!
No idea at all - my car only has 19k on it
The ceramic street pads for the HPA brakes are $129 for the set
You can get DS2500 pads for them ~$220
Indeed - hammerite to the rescue - you can also get VRS brake stickers off eBay
ECS want $790 + Shipping for the R32 Rear Brakes
(Avoid the drilled rotor disc, slotted is good however)
It's ever so common for cracks to start from the drill holes...
You will all still struggle to keep up with me...
haha...stirring.....
2018 Ralyee Green RS wagon. Fully optioned.
Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
With these brakes, he will catch you in the next braking zone...
