Results 1 to 10 of 16
Thread: Auto reversing mirror tilt
    I know the Jettas have this, but a friend playing with his new Octavia RS spied it in the manual. From memory you put the mirror on L, put the car in reverse and set the angle you want, then when you put it in any other gear it should move back. Well that doesn't happen so I guessed it must be only with the electric memory seats....but then realised the Jetta doesn't have that as standard...so does anyone know if it should or shouldn't work.
    Canberra
    Most discussion is Golf/Jetta based and the general consensus (for Golf Vs) is that you need the electric seats with memory for it to function. IIRC l read a mention somewhere that you may be able to get it to work (via VCDS) on a vRS if it has factory installed rear parking sensors - but haven't heard of anyone actually getting it to work on a vRS so far. It certainly would be nice to have
    Please let us know how you get on.
    Erskineville, NSW
    I think you need VAGCOM (VCDS same thing?).
    Jan 2008
    Perth, WA
    I've got vagcom, and couldn't get it to work on the RS with the factory sensors, or the GTI with no sensors.
    Canberra
    VCDS is just the latest version of Vagcom
    Jun 2008
    Quote Originally Posted by woofy View Post
    Instead of changing gear try switching the mirror knob to O instead, coz the system is designed not to return left mirror to original position when you change gears in slow speed under 10-15kph (for example to move back-forth in completing a reverse parking) http://www.vwwatercooled.org.au/newf...7&postcount=32
    2006 MY07 Jetta 2.0 TFSI Reflex Silver, DSG, Sunroof, Bi-Xenon, Leather
    Albion QLD
    Only Jettas with factory parking sensors have the memorised tilting (regardless of electric seats) - it's pretty handy but i've found it never returns its original position once finished.. It always stays about half way down or lower than originally set!!
    2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
    Sep 2010
    Question 2010 RS Wagon
    Hi,
    Bringing back an old thread.
    Any current owners of the RS Wagons care to clarify??
    I cannot seem to get mine to work. I had F/R Sensors btw. Dealer mentioned that car is equipped with this function when I picked up the vehicle a couple of weeks back but had not have time to play around in the car till now.
    Any advice please. Thanks
    Sep 2009
    There is no mirror tilt on my10 Octavias you dealer should know better.
    It was quietly dropped when the facelift was released.
    My Škoda photos here
    Flickr : Blog
    Jun 2009
    Quote Originally Posted by K1W1 View Post
    But did pre-FL cars actually have it? The owners' manual says so but....
    Mine: Silver 2006 Volkswagen Golf Sportline 2.0FSI 6M (with a sunroof)
    Parents': Candy White 2008 Skoda Octavia RS 2.0TFSI 6M Liftback
