You want to think about this - you're not going to win unless you spend a stupid amount of money
The car has adequate traction for most circumstances
It's only in the wet and when wanting to blast away from the lights that traction is the limiting your usage of power
You really need to progressively ease into it - but a poor road surface will still be a problem
I have tried to improve this with high end tyres which helped but does not go far enough
Running 235~245 tyres is likely to help but there are issues and costs going down that path
My current thinking is FWD with 180kw+ needs haldex 4WD
I will factor this into my next car purchase decision
The Eibach springs on stock shocks work well
They help overall handling but not acceleration from standing start
(I have Bilstien shocks and they make the stock shocks look bad)
The Octavia should be a little nose down when unladen to allow for full rear load
The Octavia should not feel doughy on turn in - even when fully stock
Due to the power steering there is not much feel (especially at lower speeds)
but car reaction to steering was always good for me (that was one reason why I bought the Octavia)
What tyres do you have and what pressures do you run?
The superloy control arms have built in anti lift - so you don't need an anti lift kit
(The nuts that come with these are not strong enough - use the original VAG nuts)
These are excellent for handling and eliminating axle tramp when launching
I've got them setup to give me more caster and 1.75 degrees of negative camber
The added caster has made the car track very straight without holding the steering wheel
The negative camber has improved initial turn in bite and raised cornering speeds - it's very sure footed
Another thing you notice with the negative camber, you can brake and steer into a corner
Ian was behind me judging his braking point from my brake lights, he nearly turned my wagon into a hatchback
(Although I have a BBK so my car brakes a fair bit quicker than a stock Octavia)
My Octavia is very sure footed and fun to drive
It's quick on standing starts but I can't use all the power until 3rd gear (maybe 2nd gear on good road surfaces)
Even so
- average cars have little hope of beating me off the line (but you need to control that right foot - restraint!)
- powerful cars get close until they reach for 2nd gear when my DSG laughs at them
2012.1 Skoda Octavia VRS DSG Wagon - Carbonio cold air intake and pipe - HPA Motorsports BBK 355mm rotors 6 pot calipers
APR Stage II ECU - APR 3" exhaust down pipe & high flow catalyst
APR/HP Roll bars - Eibach springs and Bilstien shocks
Supaloy lower control arms - Enkei 18*8 Wheels
