Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 69
Thread: APR Dump pipe stage 2 noise
  1. #41
    Mar 2013
    Shire, NSW
    Thanks for everyones input!
    Ok so I have increased tyre press's to 38psi and yeah there is a slight improvement in feel so thanks!
    After a bit more research and thought going to go with the Eibach Pro Kit Springs and Supaloy LCA's which should finish off the car nicely. Just got to source the bits next week and have them fitted up!
    Have thought about the torque arm insert but I read too many negative comments on vibrations in idle and reverse with the DSG which kind of turns me off I want to keep the car a pleasant daily driver.
    MGT
  2. #42
    Dec 2012
    Sutherland Shire, Sydney
    The left hand side is a pain to install on a DSG car,
    you have to unbolt the gearbox and lift it to clear one bolt
  3. #43
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by donweather View Post
    I can 2nd Martin's comments on the superaloy control arms. Whilst my car is still stock (ECU I mean), these superaloy arms have eliminated 95% of my axle tramping, although as Martin has stated, this comes back on ****ty/bumpy roads. Turning into cornering under hard acceleration is much more response with these control arms also. Best investment I've made on the car thus far. Just debating whether to go Stage 1 or not if Martin is saying he can't use all of the power anyway??
    So can I ask a question to those that have the LCA. Do they soften up with time? I'm noticing a bit more axle tramping occurring of late? So again I'm questing whether to tune the car if I'm getting axle tramping under stock.
  4. #44
    Erskineville, NSW
    Just tune it. As others have said, it isn't for the off the line take-off, it's for the overtaking & 3/4/5/6 midrange grunt. You just have to re-adjust to use the throttle as a linear control rather than an on/off switch
  5. #45
    Ballarat, Vic
    More power also doesn't necessarily equate to more axle tramp either. I'd be looking at tyre pressure first and then move on to tyre compound as these are the most common causes of axle tramp.
    Sent from my GT-I9305T using Tapatalk
  6. #46
    Jul 2010
    bingo!
    its all about the foot control.
    learn the sweet spot & u'll b gleaming everytime
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  7. #47
    Jul 2013
    Caulfield, VIC
    I'm running stage 2 on petrol manual and couldn't be happier. The dogbone insert helped the most with tramp, it only does it now on rough bumps and in the wet. Running these ps3's the wheels spin a little in 1 and 2nd but it's still a lot faster than stock through these gears. As stock it only slightly just spun in first on a good road, now it's easy though. I made the car the way it is to enjoy mountain cruising, and track once or twice a year- this leaves me running it in 3-4th gear 80% of the time, and for this it's perfect. Power is soo useable, and tramping not a problem, even in wet conditions in 3rd+
    Sent from my HTC One X using Tapatalk
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
  8. #48
    Erskineville, NSW
    For those of you concerned with vibration from the dogbone insert, I fitted half of a butchered insert into my car and I don't get vibrations.
    Also, the more miles you have the more movement in the original insert as they flex more over time. I didn't do mine until after 100,000km.
    Mysticality: Where did you get yours for $20?
  9. #49
    Jul 2013
    Caulfield, VIC
    I have one brand new whiteline to suit the newer style for $30, never fitted
    My RS build thread
  10. #50
    Ballarat, Vic
    Quote Originally Posted by MountainBikeMike View Post
    How much do these help with axle tramp?
