Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 69
Thread: APR Dump pipe stage 2 noise
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by dArK5HaD0w View Post
    APR's RSC exhausts achieve this perfectly - its the whole reason why i got it.
    for an off the shelf solution - the one that fits on the mk5 jetta also fits the octavia. no modification required - bolt on.
    part no. is FE100021.
    great noise and farts
    I assume this is for the Occy Sedan only and wouldn't fit the Wagon?
    Jul 2010
    Quote Originally Posted by donweather View Post
    Not sure about it fitting the wagon - I haven't enquired.
    I think it will, as I wouldn't have thought there is any difference in the under-body floor plan between the liftback & wagon.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Mar 2013
    Shire, NSW
    Ok spoke to some APR dealers today and sounds like APR dump pipe with Stage 2 will give me exactly what I want as far as noise and performance goes. Little to no difference in noise when driven softly but when on step will be more throaty, no more than say the level of the Golf R.
    Thanks for everyones input, just got to go and get it done now! Service is due now so after that is done off to APR!
    MGT
    Jul 2010
    Quote Originally Posted by MGT View Post
    good man.
    let us know when its done.
    Probably best to take it in stages anyway. Put the DP on and see how you like it. Then you can decide whether to put the cat-back section on if you still feel the need for a louder exhaust note.
    Let the fun begin
    Dec 2012
    Sutherland Shire, Sydney
    I've got it on my wagon - not a lot of overlap in the join but just fits ok
    Jul 2010
    downpipe only = CD100013 (mk5 gti, jetta - fits octavia rs)
    catback only = CD100026 (mk5 jetta - fits octavia rs)
    full exhaust = FE100021 (mk5 jetta - fits octavia rs)
    interestingly, i only paid $2495 for mine. the goapr website now lists it as $2750.
    prices must've gone up on the past 2-3 months!!
    on the TSI........
    apr stg 1 = around 145kw atw
    apr stg 2 w/ stock cb = around <160kw atw
    apr stg 2 with full intake and exhaust = around 165kw atw
    bluefin stg 1 = around 143kw atw
    bluefin stg 2 with full intake and exhaust = around 164kw atw
    giac stg 1 = around 150kw atw
    giac stg 2 with full intake and exhaust = around 165kw atw
    stock is around 125kw atw.
    Stage 1 feels how the car should have been from the factory. Very noticeable but a level of refinement
    Stage 2 the car feels modified. It's got a bit more grunt, but i doubt in real terms its any quicker due to traction limitations and speed limits.
    Stage 2+ is worth it just for the DSG farts though...
    Dec 2012
    Quote Originally Posted by GOAPR AU Web Site
    Stage I software give you higher peak numbers of 254 horsepower (189kw) and 297lb-ft (402nm) of torque,
    but also gains of up to 61 horsepower (45kw) available at lower rpms
    Stage II software gives 276 horsepower (205kw) and 314lb-ft (425nm) of torque
    Stage I gives the mid range a significant improvement
    While Stage II appears to be a small improvement, it's real world usability improvement is very significant.
    The Stage I top end performance is worse than stock, it takes longer to rev out
    Stage II cleans this up, the engine breaths and performs much better right to the red line (pulls hard)
    The Stage II mid range torque boost occurs over a wider RPM range - awesome pulling power
    If you don't drive your car car firmly/quickly (to red line) often then stage I will be fine
    If you do enjoy enthusiastic driving to red line often, go directly to stage II
    Jul 2013
    Caulfield, VIC
    on the TSI........
    Hey man,
    Do you or does anyone have timeslips or rough ideas of the 0-100 times for each of these progressions?
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
    Dec 2012
    The published 0-100km/h times are for the hatchback running 100 octane fuel in europe
    The wagon is +100kg~150kg and we have 98 octane fuel - in stock form it does not do 7.5 sec as marketed
    Stage 1 does not get you below 7 seconds
    Stage 2 with semi slicks can get you to 6.5~6.6 seconds (have to warm up the tires and make a good start)
