Results 1 to 10 of 11
Thread: Anyone know the width and offset of these? Advice for offset?
    Jul 2007
    Canberra
    Hey guys,
    Trying to work out what fitment to go for with some after market wheels on my 08 VRS wagon. At the moment I have these factory wheels:
    https://preview.netcarshow.com/Skoda...06-1600-0f.jpg
    Does anyone know the width and offset of these? Trying to work out what to get so they sit a bit more flush but don't want scrubbing. If anyone can reccomend a width and offset to achieve this it would be greatly appreciated
    Thanks guys
    Simon
    Forever blowing bubbles.
    I believe they're Zeniths, 18 x 7.5 ET51.
    Pretty sure you'll find the fitments for the Skoda will be similar to the equivalent Golfs, possibly with a little more room in the rear guards again.
    Something in the 18 x 8 ET45-48 range would look good and not generally cause any rub issues - you can go up from there but then risk the possibility of scrub depending on your suspension.
    Would recommend checking into what some of the Skoda guys have done as I am far from an expert.
    Jul 2007
    Canberra
    Thanks Dutch, good info
    Nov 2010
    NSW
    According to this they're 7.5in wide and ET51 OCTAVIA ALLOY WHEEL ZENITH VRS 18 INCH 2005-2008
    I'd try an 8 wide and et45-40.
    2012 Yeti 77TSI, Candy White
    ydad.com.au: musings of a dad growing up - the blog.
    cbay.com.au: photography, video, design - creations.
    Jul 2007
    Canberra
    Thanks cbay, probably looking at getting some of these:
    ENKEI T6S 18x8+45 5-112 MatteBlack
    They fit the specs that should suit.
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by Pullstarter View Post
    I have the exact same wheel specs on my 2012 vRS wagon with 225/40/R18 tyres. The fronts sit pretty close to flush with the stock guards and the rears are about 5-7mm in from the guards. If spacers were legal I'd whack a spacer in the rears for sure.
    I find the following website very handy for comparing
    Custom wheels, wheel tire packages for your ride - RIMSnTIRES.com
    Jul 2007
    Canberra
    Quote Originally Posted by donweather View Post
    Thanks Don good to know!
    Oct 2009
    Mitchelton, Qld
    I'm about to go to 235 tyres to get a little extra width on the rears.
    Bowral, NSW
    Largest I'd say to go is 18x8 ET48.
    I have 18x8 ET44 and with 235/40R18's they scrub all four corners. With 225's they're not so bad.
    Going back to some 18x7.5 ET51's as soon as I find some that fit, though - these are too heavy!
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Jul 2007
    Canberra
    Quote Originally Posted by Mysticality View Post
    Is yours lowered?
