My only question is - why would you??
I check my tyre pressures weekly on my 2010 RS (run 38 PSI fronts, 36 rears), using my own little hand-held gauge, and I add air when required. Is it really so important to have a tyre pressure monitoring system when you can buy a $20 pressure gauge from supercheap or similar and just keep an eye on the pressures yourself now and then?
Maybe I'm somehow failing to understand the value of such an after-market on-board system as you've proposed??
