Results 1 to 10 of 12
Thread: Anyone interested in a Group Buy - aftermarket Direct TPMS system?
    Apr 2009
    Hi all,
    I drive a 2010 Octavia VRS (petrol) and was interested in installing an after market direct tyre pressure monitoring system (TPMS). I don't consider the OEM provided indirect TPMS entirely reliable, as I found out on a recent trip.
    I tried finding out if a VW Passat or other direct TPMS systems with OEM sensors could be retrofitted to the Skoda, but everyone I've spoken to says 'no' or 'extremely difficult' and costy.
    After reviewing quite a few after-market products, I've narrowed down on two systems. One is from Orange Electronic, which is quite popular in the USA, and also given as a sample on Maverick's website (Fitting a direct Tyre Pressure Management System (TPMS) | my-gti.com)
    Sample ebay price and details for Orange P409S TPMS - Orange TPMS Universal Tire Pressure Monitor 4 Sensors | eBay
    The other one is from KiPoint (also sold as ORO in USA). It comes in various forms, but it is very close match to the one from Orange.
    Sample ebay price and details - Passenger Car 4 Wheel TPMS Kit-Display Version B | eBay
    I have already seen the Kipoint system on a friend's Toyota Corolla, and it works like a charm. It offers a bit more information than the Orange one, and has more re-setting options for rotating tyres e.g. diagonal rotation, etc
    I wanted to know if anyone else is interested in a group buy for either of the systems, or if there are any other systems out there which are similar in price and functions. I don't really like the external type sensors such as TireDog, since they can be bitch when filling air, due to their anti-teft nuts.
    Also does anyone have any experience in South Australia for hard-writing the unit once I receive it? Can normal auto-electricians / garages do it? I've tried various DIY guides from VWvortex, but am not really confident in messing around with the fusebox.
    Thanks
    MY10 Skoda Octavia RS | 2.0TSI | DSG |Candy White | Liftback | Xenons | Rear Wiper | Columbus | Skoda Bluetooth
    (Ross Tech Micro-Can - can assist with basic mods, configuring bluetooth & Sat-Nav and running scans - appreciation in terms of a six pack is always welcome!)
    Jul 2010
    Emu Plains, NSW
    My only question is - why would you??
    I check my tyre pressures weekly on my 2010 RS (run 38 PSI fronts, 36 rears), using my own little hand-held gauge, and I add air when required. Is it really so important to have a tyre pressure monitoring system when you can buy a $20 pressure gauge from supercheap or similar and just keep an eye on the pressures yourself now and then?
    Maybe I'm somehow failing to understand the value of such an after-market on-board system as you've proposed??
    Erskineville, NSW
    most leaks are slow leaks. The lower profile tyres on our cars tend not to show low pressure as obviously as they used to - especially on the rear of a FWD.
    I belted a pothole in the Cabrio once and tore a 10c piece size hole in the sidewall of the front left, hence zero pressure. I just thought I'd simply bent something and continued all the way from Bringelly to Liverpool with the steering pulling left until somebody pointed it out to me.
    Suprisingly, I check my tyres quite regularly too but I think a TPMS of some description isn't a bad thing.
    Jun 2009
    No thanks, the standard tyre pressure monitoring system works just fine for us .
    Mine: Silver 2006 Volkswagen Golf Sportline 2.0FSI 6M (with a sunroof)
    Parents': Candy White 2008 Skoda Octavia RS 2.0TFSI 6M Liftback
    Sep 2009
    I got a small nail in the OSR over Christmas the first I knew about it the little light came on on the dash so I pulled off the freeway and visually checked all the tyres. No visual difference so I went to a nearby servo and put air in, the OSR was at 20psi or thereabouts, low but in no way flat. Checked the tyres again the next day using my gauge at home with cold tyres and they were all within 1-2psi of each other so I balanced them up. Ten days or so later tyre warning light again this time while I'm on the GOR so pull into Lorne and sure enough the OSR was down near 20psi. Topped it up and went in the next day and had it checked which is when they found the nail.
    I'm more than happy with the way the standard system works at this point but I'd like to hear what the actual advantages of a TPMS system are.
    My Škoda photos here
    Flickr : Blog
    Jan 2008
    Quote Originally Posted by K1W1 View Post
    And that's why a proper TPMS is useful. The indirect TPMS is useless as it relies on the end user to reset the system and it can take ages to warn of a leak and by then tyre damage or car damage may have already occurred.
    Information on Direct and Indirect TPMS is here - Volkswagen Tyre Pressure Monitoring System (TPMS)
    Direct TPMS will pay for itself through fuel savings alone, the potential to save you through having tyres that are always inflated correctly and notify you the moment air starts leaking or the temperature of the tyre starts increasing is priceless IMO and these benefits are why the USA made direct TPMS mandatory. The savings they will make in reduced accidents/deaths and fuel savings are enormous across the whole country.
    Jan 2008
    Quote Originally Posted by RSOK View Post
    Can you check the pressure and temperature of the tyres every few seconds when driving? There's your answer.
    Sep 2009
    Quote Originally Posted by Maverick View Post
    I get sceptical about these sort of claims on the Internet or anywhere without source references.
    Flickr : Blog
    Sep 2009
    Do the tyre pressures and temperature change to the point where you need to know every few seconds? There is your question.
    Flickr : Blog
    Jan 2008
    The link to my website constantly refers to the FMVSS 138. A google of this comes back with this draft document - http://www.nhtsa.gov/DOT/NHTSA/Rulem...-fmvss-138.pdf
    There are unquantified benefits related to crashes caused by blowouts, stopped vehicles
    with flat tires, handling characteristics, and hydroplaning. An estimated 23,000 crashes
    and 535 fatal crashes annually involve blowouts or flat tires. Since the agency does not
    collect tire pressure during its crash investigations, the agency cannot estimate how many
    crashes are caused by the influence that low tire inflation has on blowouts, vehicle
    handling, and hydroplaning. Theory and limited testing show that low tire pressure has a
    significant impact on all of these.
    There are non-quantified costs and benefits that include the extra time it takes to inflate
    tires more frequently, the cost to replace batteries in some direct measurement systems,
    potential maintenance costs of TPMS, the property damage savings from avoiding
    crashes or reducing delta V in non-preventable crashes, and the savings in time and
    congestion from avoiding crashes.
    And there is plenty of information on fuel savings, tread savings and so on. The final documents have more detail on this.
