MFSW with paddle shift:
Skoda Multifunction Steering Wheel - 3T0419091H E74
AFAIK, and from looking at briskoda, its a matter of installing it, and then coding for MFSW. assuming you have the correct controller. a quick scan will give you the result of that.
I guess they would have had to make another steering wheel variant, but had to do the paddle shift for the DSGs to compete with VW. Then again the man RS steering wheel was it's own variant.....weirdest thing ever really. It was the only negative when I bought mine years back, and to be honest I hadn't noticed until pickup.
They do make the variant steering wheels and controllers, without the paddle shifts. That is what you buy form skodateile.cz. Has the RS badge, you can even opt for red stitching, or smooth leather instead of perforated. It is crazy as the paddles are an optional extra for the DSG anyway.
MFSW should be standard across the range, manual or DSG.
2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
Been emailing Ales at skodateile.cz, has recommended for my car to get the 5kO 953 549 B steering control module. He said the 5kO 953 569 H is not compatible, from other sources they just list the 569 H version as replacement for 549 B.
The 5kO 953 549 B is listed as the highline version on rosstech wiki so should work, it is cheaper too so that's a bonus.
Steering Wheel Control Module Versions - Ross-Tech Wiki
Anyone interested in my original wheel? It is the red stitch/perforated leather non mfsw style approx 2 months old, assuming everything works after the upgrade that is!
Going to order my parts next week. It will be the 549 B controller as well.
Ales suggested changing the stalks as well as control for MFD is on the wheel but i an not sure about this. I am used to MFD control from the stalks as i have this in my current other VAG cars. One with mfsw one without.
The RS is only 8 weeks away so everything should line up nicely.
He recommended the same to me about the stalks, doesn't really bother me having the original one there with mfsw so just going to keep it. According to threads I've read on it once the new module and MFSW are installed both controls will still work fine.
Now the wait for the parts to turn up....
Update: Received my new wheel today, hoping to put it in on the weekend if everything goes well.
If anyone in Melbourne is willing to help with the coding after it's in let me know, posted a thread in VCDS section but updated here in case some people don't read that section often.
VCDS In Melbourne
Lemme know how it goes... If it works, I'll follow suit.![]()
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
