Results 1 to 4 of 4
Thread: aftermarket wheels and Bolts...which should be used??
    Feb 2010
    Camden NSW
    So, from experience with the Tiguan, and hearing other comments from VW/Skoda owners, I beleive that we have to use a specific type of bolt with fitment of new wheels??
    Is that correct?
    If so, what is the type of bolt that must be used, and why is that?
    Does is affect handling, or cause vibrations?
    Does the wheel itself have to be made differently in order to accept the proper bolts?
    2018 Ralyee Green RS wagon. Fully optioned.
    Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
    2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
    Sep 2006
    West Sydney
    I think you're referring to the seat taper of the wheel lugs. Stock wheels accept ball-seat wheel lugs whereas most aftermarket (not all) accept conical/tapered wheel lugs. Google them up and you'll see the difference. Using ball-seat wheel lugs on wheels that accept conical wheel lugs will cause damage to both the lugs and wheels, and if not tightened properly will work loose more easily.
    Sent from my iPhone using Tapatalk.
    Dec 2012
    Kingston, ACT
    Yeah are you talking about the stud (bolt) or the lug?
    They'll be a certain thread and length, but whoever supplies the wheels should provide them or use your existing ones (with the exception of adding a gorilla lock-nut or something..)
    Biscay Blue 2009 R36 Wagon
    RNS510 w/ Reverse Camera | Sunroof | Auto Tail Gate | 30,000kms
    VCDS Changes: Rain Sense Auto Close | Tear Drop Wipe | Lock/Unlock Beep
    Checkout my thread
    Feb 2010
    Camden NSW
    That is what I am concerned about...whether or not the wheels will fit properly and tighten correctly if the bolts are not correct???
