Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: AC drain pipe clogged (so stinky)
    Dec 2010
    Ringwood East
    Hey all,
    Just wondering if anyone has had to deal with a clogged AC drain pipe, and if so, where is it?
    Over the past week I've noticed a foul smell every time I got in the car, it seemed to get worst every day.
    To the point it was almost unbearable, it is an all consuming stink, just like the one out of Seinfeld!
    I steam cleaned the cabin top to bottom, coated it in bicarb, air fresheners and even bought a new cabin filter and the stench lives on!
    After some web research, I've deduced that it must be bacteria, fungi and spores growing in the vents... and probably a blocked AC drain pipe.
    Has anyone had this problem before?
    I'm attempting to sort it tomorrow but dont really know where to start, any help would be much appreciated!
    NOW: MY15.5 Race Blue RS
    THEN: MY10 Black Magic RS
    Mar 2013
    Brisbane QLD
    it wont be a blocked drain. if it was blocked you would have wet carpets by now and as the weather is not humid any more (Brizzy anyway) you dont see the a/c dripping under the car onto your drive... a lot of cars are smelling like this at the moment usually when the a/c is turned off and just blowing air.... you can buy a proper bacteria spray for this issue... its like a insect bomb you let off in the cabin with the windows closed and recirc turned on for a while..sure places like autobarn would sell it....VDUB....
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Dec 2010
    Ringwood East
    Thanks VDUB!
    No carpets are dry, so mustn't be the blocked drain.
    I'll check to see if there's water leaking. Yeah the smell is discussing, and I've got a really strong stomach but after an hour, it makes you wanna hurl!
    I'll swing down to repco tomorrow and see what I can find.
    Thanks for the tips!
    Mar 2013
    Brisbane QLD
    usually the smell goes when the a/c is on.. the smell is usually with just the blower on and A/c turned off..... you might not see the a/c dripping as its not humid and its not having to take moisture out of the cabin air... good luck...VDUB...
    Sep 2009
    Rotting leaves in the air intake under the wipers on the back edge of the bonnet?
    My Škoda photos here
    Flickr : Blog
    Apr 2012
    Perth
    Is it an old sock smell?
    Nov 2010
    Burpengary, Queensland
    I had this smell problem with air con or just the fan. I removed the pollen filter, which is not due to be replaced according to VW, and no more smell.
    Apr 2012
    Perth
    Seems to be a common problem if you do a google search.
    Bowral, NSW
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    May 2011
    Prahan, Vic
    Haven't got a dead rodent in there have you? If so it would be with the pollen filter.
