Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: 19 x 9 Rear Will it Fit?
    Jan 2012
    they understeer enough as it is. put wider tyres on the rear and youll make it worse.
    Jul 2010
    XL is not the load rating - it's the speed rating.
    I believe the octavia requires a min load rating of 89.
    Oct 2009
    Mitchelton, Qld
    RS wagon requires 92 I believe.
    Jul 2010
    Quote Originally Posted by donweather View Post
    i just checked my (liftback) tyre placard - min load rating of 615 kg, or load index of 91.
    interestingly, the build plate states an axle weight of 650 kg.
    load index & speed rating listed here.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by zei20t View Post
    On a RWD Nissan, yes - On a FWD VW, no
    Dec 2012
    Quote Originally Posted by dArK5HaD0w View Post
    W is the speed rating - XL means eXtra Load
    Dec 2012
    Some tyre loadings - not looing very good for wide 19":
    255/30/19 91Y
    245/30/19 89Y
    235/30/19 88Y / 87W
    225/35/19 88Y
    225/40/19 89Y / 93Y
    The Golf guys are using 235/35/19 (it fits in the front wheel arch)
    Options for that tyre are:
    Continental ContiSportContact 3 - 91Y
    Continental ContiSportContact 5P - 91Y XL
    Continental ExtremeContact DW - 91Y XL
    Dunlop Sport Maxx RT - 91Y XL
    Goodyear Eagle F1 Asymmetric 2 - 91Y XL
    Michelin Pilot Super Sport - 91Y XL
    Pirelli P Zero - 91Y XL
    Pirelli P Zero Rosso - 91Y XL
    Yokohama S.drive - 91Y XL
    Bridgestone Potenza S-04 Pole Position - 91Y XL
    Bridgestone Potenza RE-11 - 91W XL
    Jul 2014
    Quote Originally Posted by Martin View Post
    Scrubbing is a steering term - I presume you mean rubbing
    It will depend on your offset, tyre size and ride height
    In NSW you are not allowed to increase rim width by more than 1"
    You may impact your insurance cover or even get defected (unlikely?)
    Next problem is the tyre size, to keep the same rolling diameter you need 255/30/19
    That's an odd size, may be hard to source, will cost a fair bit more than the stock tyres,
    they will spray dirt down the size of the car, they almost certainly will rub
    225/30/19 will give a 0.7% diameter change - will be stretched on a 9" rim (but is a legal tyre/rim match)
    235/35/19 will give a 1.5% diameter change
    Those sizes are bmw 335i sizes. I thought its 2 " will be the max you can upsize without being defect. 225/35/19 should be fitted wuth 255/30/19
    Dec 2012
    Quote Originally Posted by kaitan View Post
    Total tracking may be 2" wider - hence 1" wider wheels each side
