Results 1 to 10 of 19
Thread: 19 x 9 Rear Will it Fit?
    Sep 2014
    As the title suggests I had a search through the forum but have only found examples of people running 19 x 8.5 rears, I am looking at getting a staggered set 19 x 8.5 front and 19 x 9 rear as a B'day present to myself.
    wanted to know if there are going to be major scrubbing issues?
    Cheers,
    Andrew
    Dec 2012
    Sutherland Shire, Sydney
    Scrubbing is a steering term - I presume you mean rubbing
    It will depend on your offset, tyre size and ride height
    In NSW you are not allowed to increase rim width by more than 1"
    You may impact your insurance cover or even get defected (unlikely?)
    Next problem is the tyre size, to keep the same rolling diameter you need 255/30/19
    That's an odd size, may be hard to source, will cost a fair bit more than the stock tyres,
    they will spray dirt down the size of the car, they almost certainly will rub
    225/30/19 will give a 0.7% diameter change - will be stretched on a 9" rim (but is a legal tyre/rim match)
    235/35/19 will give a 1.5% diameter change
    Erskineville, NSW
    All that stuff that Martin said & your biggest problem will be maintaining the load rating - the R36 guys had similar issues.
    Probably Briskoda is a good place to ask as there are a few Brits there that have taken their mods to the outer limits. Once you go to 9" the ET has to be millimetre perfect.
    Dec 2012
    Good point Brad! I forgot about that, need the XL rated tyre,
    I'm guessing a 19" with a 30~35 profile will need some pretty stiff tyre pressure!
    Erskineville, NSW
    I don't think even XL cuts the mustard.
    A mate had an R36 and wanted to fit 19s & it couldn't be done legally & in compliance with the Australian placard which conveniently leaves 19s off it. The Euro model has 19s on the placard.
    Sep 2014
    Ah I see, I will ask the Briskoda guys, I want to stance the rears (with tyre stretch).
    if that falls through most likely will go through with plan B of RS4 copies (old style) in 19 x 8
    Erskineville, NSW
    You could try a consrvative width (like the 19x8s you suggest) and then get the stance using different ETs front & rear or hub spacers.
    From my experience, 8" Would work well with ET45 front & ET35 rear or just get ET45 all round & 10mm spacers for the rear
    Nov 2009
    Illawarra NSW
    But why would you want to do it ? Its not going to improve the handling on a front wheel drive and will make it impossible to rotate the tyres.
    2014 MY14 Corrida Red Elegance Wagon TDI
    2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
    2011 MY12 Yeti 77 TSI DSG.
    Erskineville, NSW
    Quote Originally Posted by Antiplastix View Post
    Some people aren't concerned about the practicality & just want the looks. Hence, Briskoda has several octavias with bagged suspension and one guy that took a red Octavia & vinyl wrapped it in.... RED!
    While the OPs ideas aren't my cup of tea, what he wants to do isn't dangerous so I'm happy to offer suggestions on how he can achieve his goals.
    Sep 2014
    Thanks I might try that, main reason I asked is the rims I want are a staggered set, I do like me some stance though.
    Bike is for the track rather than the Skoda
