Are these x 8 or x 8.5?
If x 8 and ET45 then should generally not be a problem, although with 235 rubber there might be some minor rub on hard cornering if the RS has the fender screw like the Golfs.
If x 8.5 or wider then may require further work to the camber or guards to avoid hassles.
