Results 1 to 6 of 6
Thread: 19 inch wheel fitment RS Octavia Wagon
    Jun 2014
    Miami qld
    Hi,
    I am looking at purchasing some second hand replica 19 inch Talladega wheels fitted to the (Golf R), advertised on this forum at the moment.
    The wheels are 235 35 19, unsure of offset but my research indicates possibly et45??
    My RS has lowered H&R springs (very mild drop) with plenty of room between guard and tyre.
    I'm hopeful they will fit?? Any opinions or comments would be appreciated.
    thanks,
    Dazz
    Are these x 8 or x 8.5?
    If x 8 and ET45 then should generally not be a problem, although with 235 rubber there might be some minor rub on hard cornering if the RS has the fender screw like the Golfs.
    If x 8.5 or wider then may require further work to the camber or guards to avoid hassles.
    Jun 2014
    Miami qld
    Thanks,
    dazz
    Jan 2012
    19x8.5 ET+45 not an issue. sit flush with the guards. I run 235x45x19 rubber too
    I get some scrubbing on the front over really fast hard bumps while turning. but not very often at all. there was no scrubbing while on the track either
    Dec 2012
    Sutherland Shire, Sydney
    I thought Lex had some tyre rubbing with his 235 tyres
    Jan 2012
    possibly different offset. mine seems fine. but ill let you know once I get coilovers.
