Quote Originally Posted by meremale View Post
Just for the 120k service, which I thought would be the same as per manufacturers specs for all service centres.
No, the definition of "service X" can be quite different. VW Australia run a different "standardised" check list to the rest of the world and often an independant will have their own list of service items that they have arrived at through experience of what lasts & what fails.
In theory, yours had the timing belt done at the 105km service?
Apart from that, I don't think 120k is huge as you would have / should have been stung at the 105k.
Oil + filter
pollen Filter (probably - should be done every year IMO)
Fuel Filter (might have been done at 90k)
Air Filter (might have been done at 90k)
Brake Fluid flush (depends when last done - every 2 years is the schedule)
DSG / auto fluid change + filter
So in order to compare apples/apples, you need to know what they are doing.
