If any of you guys can visit me in mt kuring-gai or on the central coast I'll scan your car for fault codes using vcds. If theres an error it will show up regardless of whether the problem goes away. I dont know about the dealer software but VCDS will show it.
to me it sounds like a sensor or mechatronics issue - being that when decellerating above 1100rpm the ecu cuts fuel to 0 to save fuel, then the fuel flow should restart below 1100 to allow the engine to keep running - OR - the dsg is not decoupling as the car stops causing the stall - or both.
I would expect some error code to be evident.
pm me if your interested.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
