Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: 103tsi brakes
    Oct 2010
    Lol. The ones I have seen are 2.4kŁ and upwards.......
    2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
    Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
    Apr 2008
    Western Sydney
    Can't say i'd ever need a BBK. Upgraded pads, discs, lines and fluid will suit me fine. My only complaint is the rears are tiny compared to the fronts!
    Jul 2010
    If the 103tsi is using the same 288mm rotor / caliper combo as the 118tsi had then you can buy the 312mm caliper carriers for <$100 pair on ebay. Add some decent 312mm rotors ($160/pair for non-slotted) and stick with the factory caliper & pads & it's a cheap upgrade
    it is also worth noting that the mk2 rs has a bigger brake master cyclinder.
    tis the same size as the ones used in the Audi S3 and Golf R.
    the mk6 GTi, strangely, has a smaller one.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Jul 2014
    Ambition measured without removing wheels looked like 285 mm front and 250 mm rear.
    Oct 2010
    There have been a few complaints that the brakes on the lower models are a bit under done. I would do pads first and see how they go.
    Erskineville, NSW
    Quote Originally Posted by Gerrycan View Post
    So the 288mm front, 253mm rear combo.
    Weird considering the front caliper piston is same size on RS & the "bigger engined" shopping trolleys. Maybe there's a difference in rear piston size or they were after a different pedal feel?
    Bowral, NSW
    I don't know about the anti nose dive trick, but it would make some sense... I never used to notice nose dive in my Mk2 vRS with stock brakes (312x25 front; 272x12 rear) but with the R32's (345x32; 310x22) I most certainly do!... Also the front tyres seem to be wearing a lot faster.
    I find it interesting the Mk3 Octy comes with GTI PP brakes from stock.
    Much difference between GTI PP and 7R?
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Erskineville, NSW
    Just the front PP brakes I believe, not the rears.
    Apr 2008
    Western Sydney
    Quote Originally Posted by Mysticality View Post
    I believe the GTI PP and R share the same brakes. Though on the Mk3 RS i think the rears are smaller than those on a GTI.
